Front Suspension Project
Old Jan 30, 2022 | 09:19 AM
Red1977Vette's Avatar
Red1977Vette
Default Front Suspension Project
Good morning!
I'm in the process of swapping out the upper and lower control arms on the front suspension on my '77. Two questions - is there a torque spec for the castle nut for the wheel hubs? I was a little perturbed to find it loose when I took the cap off yesterday. It was so loose that after I took out the cotter pin, I was able to take it off by hand. That normal?
Also, since I'm doing this project, I have to believe my coil springs are original to the car. Since they have to come out, should I replace them with new springs? And if so, recommendations on what I should put in? I don't want to change the ride height on my car but anything I can do to improve the handling I'm all about.
Thanks in advance for any and all insight!
Charley
Old Jan 30, 2022 | 09:49 AM
interpon's Avatar
interpon
I think you are supposed to seat at 12 pounds then back off to next cotter pin hole..i just snug while turning and then back off..
i would for sure put new springs in..
this may be helpful
https://www.corvetteforum.com/forums...rs-method.html
and here
https://www.corvetteforum.com/forums...-for-79-a.html
Old Jan 30, 2022 | 12:45 PM
Gordonm's Avatar
Gordonm
Yes replace the springs. You have it apart already. Springs do fatigue with use.
Old Jan 30, 2022 | 06:50 PM
60 SHARK's Avatar
60 SHARK
To answer your first question, Yes, its not unusual, especially if it hasn't been done for a while.
Second ,, if you like the ride height NOW, I wouldn't mess with new springs.
No way to tell what height you'll have with new coils till they are installed. Might be same,, might not be same.
Old Jan 30, 2022 | 07:08 PM
GTR1999's Avatar
GTR1999
I set the front bearings like I do the rears and it's not loose.
Put the torque wrench away for front bearings.
snug them with a wrench, back off, snug again, back off, snug by hand check pin hole and pin if there back off but less then 1/2 a flat and pin. Check for endplay should be very little. If you have to back off a flat you can change the index by rubbing the nut on a piece of emery or sandpaper. Then go back over and pin it.
Old Jan 30, 2022 | 07:28 PM
kossuth's Avatar
kossuth
Originally Posted by Red1977Vette
Good morning!
Perfectly normal. As mentioned the way these were done back in the day is while turning the hub you would tighten the castle nut to approximately what I’m guessing is 20 ft lbs (I’ve always just done them with a large crescent wrench) and back the nut off until you lined up the slot. You usually want to run through the process twice to make sure everything is good and seated particularly with new bearings.
Old Jan 30, 2022 | 07:38 PM
derekderek's Avatar
derekderek
i like to feel a thousandth or 2 of play in the hub. bearings warm up and expand.
Old Jan 31, 2022 | 07:40 PM
Gralls4771's Avatar
Gralls4771
I replaced the entire front suspension and steering on my 79 last spring. I was also worried about ride height changing with new springs, so I went with coil overs to adjust if needed. Much more expensive than springs so it depends on your budget.
To Front Suspension Project
