Headers
Old Feb 10, 2022 | 09:25 PM
Golferdad's Avatar
Golferdad
Default Headers
I just purchased a 1981 Vette, original engine,and knew right off the bat that I was going to need a set of long tube headers,so ordered some stainless steel headers,waiting on them to arrive,but was surveying them today,and noticed I might have jumped the gun,because,I noticed there’s all kinds of lines running from the manifolds on both sides,I’m assuming some type of smog control,so how can you if possible to hook them up. Thanks.
Old Feb 11, 2022 | 01:54 AM
Bluegoose95401's Avatar
Bluegoose95401
those are air injection lines that run from the smog pump to the exhaust manifolds. What you have to do depends if you need to smog ( or any emissions test) the car and if you do what state your because they requirements vary from state to state.
Old Feb 11, 2022 | 03:09 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yes, I looked at Mr. Puddings profile, doesn't say where he's from.
If you don't need to pass emissions. Start pulling all that unnecessary junk off of your engine. If you do have to pass emissions, well then, your sunk.
Old Feb 11, 2022 | 08:15 AM
pspicci's Avatar
pspicci
Maybe something like the hedman 61303 would work. they come with the AIR fittings on them. there may be other header companies that make headers that are AIR compatible.
Old Feb 11, 2022 | 09:19 PM
Golferdad's Avatar
Golferdad
I live in SC,and we don’t even have inspection stickers here,so if I could redirect them or just cap them off.
Old Feb 11, 2022 | 09:23 PM
Golferdad's Avatar
Golferdad
Yes,no problem in SC,we don’t even have inspection stickers here,so no kind of emissions here,so,I can start snatching **** then.lol Thanks
Old Feb 12, 2022 | 08:58 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I urge you to have the headers ceramic coated before install......this is almost necessary on a C3 Vette.....the amount of heat an uncoated header generates in a C3 engine compartment is staggering.....especially if the timing is not set correctly.
Jebby
Old Feb 12, 2022 | 12:48 PM
ctmccloskey's Avatar
ctmccloskey
I have had great experience with HEDMAN Headers as they fit both times I put them on without so much as a tap. They fit well on the 427 at least. The ceramic coating will make a big difference inside the engine compartment. I have the Hedmann headers in silver ceramic and they look sharp when new.
The header companies are now starting to warn people not to use ceramic coated pipes on engines while "breaking in" the engine as it can overheat the coating and cause it to fail prematurely. If you are using Higher compression in your engine then you might want to have the headers custom coated in the higher temperature resistant ceramic material. This is a lesson I learned painfully...
HOT pipes near fiberglass is a good way to burn the Corvette to the ground. Keep the air gaps big enough to prevent heat damage or searing the fiberglass. On my 1968 with it's 427 and 4 speed there is plenty of room around the pipes. I am however a big supporter of D.E.I. Heat protection sleeves.
Old Feb 12, 2022 | 02:56 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
Old Feb 12, 2022 | 03:13 PM
ctmccloskey
Most of the emissions equipment is not required by the individual States, instead the Federal Government is responsible for that stuff. It is not against the law to remove or disable the equipment in Virginia but it is illegal to remove the emissions equipment by the Federal Government. Who has final say? I would be careful and not underestimate the power of the feds.
I keep my 2 Corvettes both "fully legal" to drive anytime by not having Antique license plates. Virginia is cracking down on cars with Antique Plates being used regularly. I also have both "Safety Inspected" as needed by the State of Virginia and my C4 needs and gets it's emissions tested every two years.
I LIKE having another set of eyes check my cars to be sure they are safe. I am a good enough mechanic but having another expert look it over is a good thing in my opinion. The emissions is more for diagnostic purposes as it shows if everything is working properly.
Old Apr 26, 2022 | 10:12 PM
ScottinMaine's Avatar
ScottinMaine
Assuming the Feds were not going to chase you down for adding headers and a true dual exhaust, what else gets shitcanned besides the air hoses and the air pump?
Old Apr 27, 2022 | 08:46 AM
jimco84x's Avatar
jimco84x
2019 C3 of Year Finalist (track prepared)
Originally Posted by ScottinMaine
Assuming the Feds were not going to chase you down for adding headers and a true dual exhaust, .......?
The are FAR too busy chasing people down for improper pronoun usage.
Old Apr 28, 2022 | 10:27 AM
ScottinMaine
Not the sparkling tech advice I'm used to from the C3 forum. It wasn't a brilliant question, but it looks like a lot of minor things get impacted when you swap out the manifolds for headers. I'll figure it out as the parts fly.
Old Apr 28, 2022 | 10:49 AM
scottyp99's Avatar
scottyp99
Originally Posted by jimco84x
The are FAR too busy chasing you down for improper pronoun usage.
That's old news. The big thing lately seems to be "ghost guns". Personally, I don't get it. Why would a ghost even need a gun, anyway? I think the next big thing will be ending a sentence with a preposition.
Scotty
Old Apr 28, 2022 | 11:08 AM
augiedoggy's Avatar
augiedoggy
Jebby
I have uncoated stainless sidepipes. I have a couple real time temp sensors mounted under my hood including one next to the passenger side header by the ac relay. What ive found is while the temps do climb while the cars not moving, they drop to basically ambient air temps within 2 minutes of the car moving on the street in my car. So I guess how the car is used and how much time it spends sitting, idling makes a fair difference in how much of a concern this really is. Full disclosure I have a greenwood high rise hood with the vented cowl area and dual electric fans which often turn on only in those conditions where the car is sitting still or close to it.
I installed the sensors to determine if a CAI really would have significant gains for me and what Ive determined is the only time my intake air temps are higher than ambient is while and immediately after taking off from a standstill so while if I was racing that would be a big deal, for my spirited driving I find its not.
I have a temp sensor both in this air cleaner and down by the silver relay mounted in front of the heat exchanger.
Old Apr 28, 2022 | 04:28 PM
stingr69's Avatar
stingr69
Scott
You toss the AIR pump, the valves, the trees and the Early Fuel Evaporator system hoses/switches. Ususlly you toss the Exhaust Gas Recirculator valve as well. The distributor and carb need to get recalibrated because you tossed the EGR. On an '81 you would need to replace the carb and distributor in order to do all that due to the computer. I don't know exactly what year you are working on but these are generally what people are doing to desmog their vettes.
Old Apr 28, 2022 | 04:34 PM
ScottinMaine
Thanks, stngr69, that's what I was getting at. It's a 77 L48, so I can deal with the distributor and carb, they were going to get the Lars treatments anyway.
To Headers
