BBC 496 and 8 quart pan
Old Feb 14, 2022 | 06:21 PM
ddawson's Avatar
ddawson
Default BBC 496 and 8 quart pan
Question about larger Champ oil pan 8 quarts and my 496 stroker.
https://www.champpans.com/products/p/cp208/
I got everything done and added 6 quarts at this point. I made the switch from the stock style to not whip the oil into foam.
Dipstick shows a little below add a quart. Was wondering if this is a good level or should I add more?
Old Feb 15, 2022 | 12:34 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
It all depends on the RPM range you plan. The front part of the pan that causes most windage issues on a 4.25 stroke. It's just real close and oil can't get away.
I run a Milodon 31188 Drag race stepped pan and it's fantastic. One of the best wet sump pans and it will fit in a Vette. It has a kickout along the right side to allow oil to escape and a deeper front section. And the best thing to me is the sump actually 'steps in" vs kick out like most. So whatever oil gets back to the pan will be higher over the pickup. I compared it against my previous Moroso pan (that was fine on my 427 but terrible on the 540/555) and found the same amount of oil was about 5/8" higher over the pickup which doesn't sound like much..but is a lot when you're only dealing with a couple of inches or so of oil.
I'd try it with the 6 qts and verify it hold oil pressure at your RPM range. Too much will kill power and foam the oil on a pan like yours. It might even like a half QT less.
I run a long truck style oil filter also to carry a little extra oil capacity for cooling but keep it out of the sump.
JIM
Old Feb 15, 2022 | 07:18 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Before I install unknown pans like this I put them on a bench and fill them full of oil to see how much it takes before the level goes above the "bathtub" or the sump baffle.......you want the level below this. And although a company may claim that it is a "7 quart" or "8 quart" pan......I have seen that not to be the case many times over the years......
If the oil level is above the baffling......this is bad.....
I think I would call Champ short of removing the pan......
Jebby
Old May 14, 2024 | 02:20 PM
benjiboy's Avatar
benjiboy
Any updates to this ddawson? I'm eyeballing the same exact pan for my 496.
Thanks,
Old May 15, 2024 | 12:25 AM
ddawson's Avatar
ddawson
Thanks,
I have a new engine which uses a Gen5 block. Still used a Champ pan which fit great.
To BBC 496 and 8 quart pan
