Quick 350 question for the engine guys...
If I were looking for cheap preloaded versions of these I would feel comfortable buying these for a bit more. https://www.ebay.com/itm/33391577918...QAAOSwZQxW2LMx Skip has been selling these for years and I think he was the first honestly. It sounds like the forum member above is a good option too since he can tailor to your cam choice.
Wow. Those look damn good from where i'm sitting. Too good to be true you think? Or legit. I'd still have only 9:1 CR... but thats only about a 4-6% loss from 10-10.5:1...
https://www.ebay.com/itm/31312130991...pid=4027623388 Boot77 did a comparision of those vs these on youtube and found these to be much better.
and this head porter did a good series on these heads. hes also done some nice comparisions of brodix heads vs others. he doesnt appear bias and points out the flaws/ weaknesses he has found
The thing I mentioned in another thread is I see people are quick to warn against the cheap heads saying they will destroy an engine yet I dont see any actual reviews or reports where thats happened and I spent a lot of time reading reviews on everything from yellow bullet to amazon. Ive seen some reviews that were so far fetched they were clearly fake but thats common it seems on amazon. I just dont think its as likely as people warn.. Places like speedway wouldnt still be selling them if they were really that bad. (Although they still sell procomp too but ive been told even those are improved now) I could totally get that one size is not a fits all application with heads and someone using these with a stock flat tappet would want lighter springs likewise someone using a big roller cam would want stronger springs. You would think due to cheap price alone more inexperienced mistakes would happen through mismatched application with these though.
Ive read and seen plenty of valve spring failures on this forum but I dont recall ever seeing a thread about valve failure honestly.
maybe for a small flat tappet a cheaper valve might live but a decent valve isnt much I cant see the sense in cheaping out there.
Same with valvesprings those are so crucial. Most feedback are from guys who just bought them, maybe had it running for a few mos "revs to 7k and goes 8 sec in the 1/8) type stuff.
I have yet to see someone tear down theri heads after 20k miles and see what kind of wear has occured. Not thrilled with the guide quality.
If those go away so does the valve job, cyl pressure etc.
on the typical 200cc Chinese head getting 300 cfm isnt too difficult at all.
Even in the video Eric had to lift the valve to .800" to get 300 CFM, When's the last time a flat tappet street car lifted the valve that far?
More interesting is that he lost flow @ .300 and .400 started to gain @ .500. In a flat tappet street car your done by .500" usually before. So him porting that head for street use, It lost flow, not gained. Notice also that the exhaust lost flow everywhere @ and below .500".
High lift flow by augering out the port is certainly achievable. What is it going to do to the port volume and velocity of the intake charge when you take a 200cc port and make it 220 cc's by doing so? I think he alludes to those facts early in the video.
High flow below .500" with a 180cc port volume or maybe 195cc port volume is what I would look at If I want to make comparisons. AFR 180cc port volumes flow better than most 195cc port volumes on other heads. That's worth noting.
2.02 intake, stock valve job Erson valves
Lotta companies post peak #s to sell heads it doesnt tell the whole story
If I had to guess with a standard build I'd guess 15CFM is maybe worth 20-24ish HP. Less if the build is not very optimal.
15x2=30
30x.8=24
https://www.motortrend.com/how-to/ai...ylinder-power/
Yeah cheap valves and springs causing failures lol
In my case, its going to take me about 15 years to get 20k on my car with as much as I drive it every summer and im likely to make more changes by then anyway honestly.
Like heads that come in early, with strong # then carry a little farther. So tempted to put the ones I posted about on mine I bet they outperform the Dart 230s I have now.
Too lazy, will sell instead.
procomps have gotten better over the yrs but would never use them personally
With what i'm building, a fast, reliable, 'attitude' car... i wholly admit i intend to be guilty ov this too. However... if there is one thing i cant stand, its cars that look faster than they are. Mine will be so goddamn light that i'll be able to lose 10-20HP over my optimal build and still will races. I want a modern engine, and there is just something profane about a sick chop coming from a computer car... Another saving grace, beyond the light weight, is that it is harder to under-engine a computer car...
I LOVE the sleepers... but i've taken that to extremes too... and its REALLY fun when you get beside a hot car... and no fun at all 95% ov the rest ov the time. Had a 73 smog-era, big-bumper 4-dr Dart, beige on white vinyl with plaid seats and steel rims with 70 series tires. No scoop or bump, no big pipes, no tach, no nothing... just a hot 440 Magnum and 727, and 3.91 posi. Thing idled like an electric motor, and somehow hooked HARD. VERY fun car... 5% ov the time. The other 95%, i felt like a teenager on his way to pick gramma up from the bingo in her car. Yeah... i like the attitude. The BEST part is... you can have a hot car, and still be a sleeper. You've just gotta be REALLY good...
