Vet1982
Old Feb 24, 2022 | 12:01 PM
vet1982's Avatar
vet1982
3rd Gear
Default Vet1982
Hello,
I’m Fred and I’m new to the forum. I have a 1982 Corvette I bought about a year ago. She was running good until lately. She was seating for 2-3 weeks and now she won’t start. I can crank the motor but that’s it.
Both injections prime for 2 seconds when I turn the ignition to on.
if I removed the eight sparks plug cables and I crank the motor I can see the sparks moving around on the distributor cap.
it looks like I have gas and sparks, I’m wondering why she won’t start.
Old Feb 24, 2022 | 12:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you checked the computer for an error code?
Old Feb 24, 2022 | 01:46 PM
Johnnyracer's Avatar
Johnnyracer
When you move the ignition key to the 'on' position, not start- but on, does your check engine light illuminate?
Old Feb 24, 2022 | 05:44 PM
Fly skids up!'s Avatar
Fly skids up!
Injectors do not prime when the key is turned on. The only time you should see spray from the injectors is while cranking. Is this what happening?
Old Feb 24, 2022 | 06:11 PM
vet1982's Avatar
vet1982
3rd Gear
yes, I have error 55 ECM defect. I had that error since I bought the vet a year ago. She always stated before even with that error.
Old Feb 25, 2022 | 02:41 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Shoot some ether down the throttle bodies open and then get in and start it......does it fire? If so...then you have no spray during crank......
If it doesn't fire then you are into the ignition......
Simple test....
Jebby
Old Feb 25, 2022 | 04:01 PM
vet1982's Avatar
vet1982
3rd Gear
Simple test....
Jebby
I used starting fluid in the throttle bodies once, before cranking the motor and it didn’t work. I’ll try again while cranking it.
I changed the distribution cap, the coil, the rotor and the ignition control module. Without connecting the eight spark plug cables on the distributor I can see the sparks going around the eight gold tips on the distributor. But when I connect the eight spark plug cables it looks like there is not voltage going thru any spark plug cables when I crank it. When I crank the motor I have about 10V DC on the +bat on the distributor. I can not believe I could have eight bad spark plugs.
To Vet1982
