Tach not working, and timing light not working.
First, my amazement at the fact that the engine actually started!
1) I put an MSD ignition in all the way 'round, 6AL iginition, and the Corvette Tach Drive Distributor, Blaster 2 coil, and Heli-coil wires.
- Now the tach dosen't work. Its the standard 'vette tach, and it worked on the original Distributor, and I didn't do anyting inside the car. I've checked the physical connection, and the tach cable is seated and tight.
2) I can't get the timing light to work. I've got a Sears fixed inductive light. I even exchanged it thinking the light bad, but same results on the second one. I can't believe I'd get two bad ones.
- Any tricks with this setup? :confused:
