Alternator light
Old Feb 25, 2022 | 03:16 PM
Alexandra Z's Avatar
Alexandra Z
Default Alternator light
The alternator light on my 81 is 'slightly' on. It is just a dim glow. It does go out sometimes while driving but it glows when at idle. I am not sure if this is a short in the light or if there is a problem with the alternator or what to think. Has anyone had this problem?
Old Feb 25, 2022 | 03:23 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Yes, had it and a new/rebuilt alt fixed it.
Old Feb 25, 2022 | 03:43 PM
Alexandra Z
thanks I was hoping for a short but afraid it was the alternator itself.
Old Feb 25, 2022 | 03:47 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
you will need to "clock" it, no question.
Old Feb 25, 2022 | 03:55 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Your car should also have a voltage gauge in the center cluster. What does your voltage gauge read when your car is idling? This will tell the real story. Does it read 14 or more volts? Is it way down at 12 volts? Turn on the lights, engine still idling, what does your voltage gauge do?
Old Feb 25, 2022 | 04:04 PM
carriljc's Avatar
carriljc
Don't trust that in car gauge.
Get a digital multimeter and take a voltage reading at the battery terminals and write those readings down - as follows:
1. Car off
2. Car running at idle - no extra loads energized.
3. Car running at idle with every load possible energized (high beams, a/c, high speed fan, directional flashers, stereo, etc).
Report back these readings.
Old Jun 30, 2025 | 03:47 PM
abc63's Avatar
abc63
Mechman is the go to if you want the best.
Old Jun 30, 2025 | 05:17 PM
HeadsU.P.'s Avatar
HeadsU.P.
Alexandra,
I 'm guessing your idle is around 500 or less.
I believe the ALT doesn't start working until 600 or more.
Old Jul 1, 2025 | 12:09 PM
sunflower 1972's Avatar
sunflower 1972
Old Jul 1, 2025 | 04:33 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Usually that's a diode trio or bridge inside. Easy to diagnose and fix with an ohmmeter once you open the alternator.
But first...check ALL the fuses.
JIM
Old Jul 1, 2025 | 04:39 PM
sunflower 1972
Old Jul 1, 2025 | 04:41 PM
sunflower 1972
How to rebuild a 10SI alternator
Old Jul 1, 2025 | 08:00 PM
MelWff's Avatar
MelWff
Over 3 year old thread
Old Jul 6, 2025 | 07:33 PM
vettebuyer6369's Avatar
vettebuyer6369
Everyone is responding to a post from 3 years ago.
To Alternator light
