With the engine off, can you feel any wobble with your hand? When you spin the fan by hand does it feel smooth with just a smidgen of drag?
The fan clutch is operated by a thermal spring and internal fluid. Kinda like an auto trans converter with fluid coupling; as the spring warms up it "locks up" and activates the internal fluid coupling. When cold you should be able to hold the fan still with the engine idling -- I don't think I'd do this by hand though. If you apply a heat gun to the front of the clutch, it should "lock up" and be difficult to turn and will want to pull on the fan belt too.
I've not heard of fan clutches creating a vibration... Are you feeling it in your hands on the steering wheel, your butt/back in the seat, or both? Or is it just an audible vibration?
your Z alignment for your drive shaft is off
your running a junk centerforce clutch
your u-joints are bad, installed wrong, or loose
your rear end snubber bolt is loose.
output shaft bearing bad
Auto,Shaft and Joints fresh assembly from a Driveshaft manufacturer. Everything appears right. It’s kind of hard to check phasing with that snubber bracket in the way.
Ok, so not flywheel balance or clutch components since there are none. since it's only when it's moving that eliminates the fan all together.
when it's going down the road put it into neutral while its still going at a good clip and the vibration is present. If the vibration stops, or changes dramatically as engine RPM comes down, then look to the transmission or torque converter balance, that doesn't seem likely though.
If the vibration continues then start looking at wheel balance or balance issues with the rest of the drive train, drive shaft, half shafts, ujoints, shaft alignment issues, etc.
If you want to eliminate the clutch fan (seems unlikely) you can temporarily tie it so it doesn't spin, it's not a mechanical fixed connection so it's free to not turn until the motor reaches a certain temp. Can't go too far or too fast but might be enough to know it's fine
M
your output shaft bearing bad.
question, at what speed does the vibration start showing? around 70mph??
