Power window conversion install help
Old Mar 11, 2022 | 02:11 PM
Jhiltonn's Avatar
Jhiltonn
Default Power window conversion install help
I got this kit on Father's Day 2020 from Corvette Central and only now am I installing it due to a kidney operation I had that summer which slowed down my restoration work! So anyways, I got all the power window door hardware installed on my 72 coupe with only the wiring harness left to install. Tested the window operation and both motors work ok!
the wiring harness in the kit was from Letric Limited. In checking all the connections shown on the green LL install sheet, I have an issue because the 2 Letric Limited connectors that are supposed to connect to the relay switch do not fit onto the power window relay switch for some reason?!?! Hopefully someone else has run into this issue? Help??
Old Mar 11, 2022 | 06:49 PM
righthanddrive's Avatar
righthanddrive
Try calling Lectric limited directly and talk to a tech. They may have installed the wrong connector fittings ,or have a fix for you.
Good luck.
Old Mar 11, 2022 | 09:47 PM
bobby70's Avatar
bobby70
I just did my. 70 should be the same as yours and every thing went into place with no problem just recheck
To Power window conversion install help
