Starter help!!
Old Mar 18, 2022 | 11:59 PM
Enwalord34's Avatar
Enwalord34
Default Starter help!!
I have an unconnected wire on the c3 i just bought dont know where it goes
Its red under the white sleeve
Old Mar 19, 2022 | 05:57 AM
Bikespace's Avatar
Bikespace
What year? I bet both of those fusible links go to the same terminal.
Perhaps a wiring diagram would help?
http://wordpress.keystonestatecorvet...m/?page_id=118
Old Mar 19, 2022 | 08:30 AM
derekderek's Avatar
derekderek
looks like small terminal. hot wire for points distributor. replacement starter has no R terminal. does it still have points distributor?
Old Mar 19, 2022 | 08:52 AM
bmotojoe's Avatar
bmotojoe
To me it looks like both the R & S terminals are there but the start circuit purple wire usually going to the S terminal is connected to the R terminal.
If it were a single terminal solenoid the S terminal would have been on the opposite side and the R terminal omitted.
Old Mar 19, 2022 | 10:08 AM
HeadsU.P.'s Avatar
HeadsU.P.
Something sure screwy there alright.
Thinking as a clock:
6 o clock position gets the mounting hardware, no wires.
9 o clock is used for old points / condenser system.
Noon gets the big red cable plus a smaller wire.
And 3 o clock (which is missing in O.Ps) gets the other small wire, I believe.
I wonder if someone installed the solenoid cap up-side-down?
Or, its the incorrect unit?
Listen to bmotojoe. He helped me a lot. He has 12 V running through his veins.
Old Mar 19, 2022 | 10:29 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What year?
Jebby
Old Mar 19, 2022 | 10:30 AM
Enwalord34's Avatar
Enwalord34
It's a 1974
Old Mar 19, 2022 | 10:38 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by Enwalord34
It's a 1974
Does it still have a points ignition?
Jebby
Old Mar 19, 2022 | 10:44 AM
Enwalord34's Avatar
Enwalord34
I plan on finding out when I get home I'm at work till 4 but I plan on unwrapping everything down there and tracing everything back to point a
Old Mar 19, 2022 | 10:45 AM
Enwalord34's Avatar
Enwalord34
I also just ordered a new starter I'll probably order a new ignition and distributor as well
Old Mar 19, 2022 | 10:58 AM
60 SHARK's Avatar
60 SHARK
REMEMBER,,, One bubba fix at a time. Don't uncoil too much befor ya get clear instruction on your remedie.
Old Mar 19, 2022 | 11:00 AM
Enwalord34's Avatar
Enwalord34
Definitely nothing is going in until I find and fix this first I've been ordering and replacing everything but the blocki have a basement full of parts right now lol
Old Mar 19, 2022 | 01:06 PM
Peterbuilt's Avatar
Peterbuilt
Or is the cap or the solenoid installed upside down, is that even possible?
Do you have a separate 'coil' next to the distributor?
You don't have to unwrap all the wires, check for continuity on the loose wire at the starter to the + (positive) terminal on the coil.
Look at the schematic to see the (yellow) wire from the starter to the coil,
When you turn the KEY to START it sends power to the solenoid (S terminal) and simoustanly to the (R) terminal and when you turn the key to RUN the power stops flowing to those terminals.
The yellow wire from the R terminal on the solenoid to the coil is shown here.
How your starter was wired from the factory.
Old Mar 19, 2022 | 01:11 PM
Enwalord34's Avatar
Enwalord34
I'll definitely check this when I get home I knew it had to be something simple when I get home from work I'll dig into it and let y know thanks
Old Mar 19, 2022 | 06:23 PM
derekderek's Avatar
derekderek
if the starter starts the car and you have a non-points ignition, don't be throwing a starter at it. the car is gonna go "buy me this. buy me that." and what you buy her ahead of time won't be what she wants. so she will just tell you to buy her something else. you also don't have to drive it tomorrow. pull the part. see what it needs. then start looking for it. if you are replacing the starter anyway, not with another full size gm starter. there are 2 different types of permanent magnet gear reduction starters that are superior and weigh much less when you are holding them over your head trying to thread bolts in.
Old Mar 19, 2022 | 06:41 PM
Enwalord34's Avatar
Enwalord34
I was just under it inspecting the hook ops the unconnected red is actually a yellow the main power bolt was lose and was moving around by touching it I tightened it back down the sleeve on the ground to the bell housing has started to fall away I'm rewraping it
Old Mar 19, 2022 | 06:44 PM
Enwalord34's Avatar
Enwalord34
Currently waiting for battery to charge to start testing wires
To Starter help!!
Old Mar 19, 2022 | 08:39 PM
Enwalord34's Avatar
Enwalord34
While the battery was charging I replaced the alternator plugged the battery in at what the charger said 88%car started right up on a cold start the wire has no voltage so I believe it was bypassed but after letting it idle for 20 minutes I shut it down went to start it again and it acted like it had a dead battery pulled the battery charger says 100% so I'm thinking the starter is on its way out the door ?
Old Mar 19, 2022 | 10:52 PM
Peterbuilt's Avatar
Peterbuilt
You might want to make sure that the starter to frame ground wire is clean and tight.
See #3
Also check the battery ground under the driver's seat.
See #1
Old Mar 20, 2022 | 01:36 AM
Bikespace's Avatar
Bikespace
Excellent post! I had an intermittent issue in my 80. I jacked up the car and cleaned the negative battery connection, then found the issue in the battery connector itself.
