Fuel Filter connection leak....confused :/
Old Mar 20, 2022 | 05:18 PM
njvt13's Avatar
njvt13
Default Fuel Filter connection leak....confused :/
Today I changed my inline fuel filter on my 73' (which I temporarily installed a few months ago as a first line of defense from debris getting into the carb). It is installed in between the main line and fuel filter. I also changed the paper filter in the carb. For me this is routine, I have done it may times. However, earlier today, after I finished, the metal line running from the fuel filter to the carb is leaking at the fuel filter connection. When changing the paper filter, I didn't do anything out of the ordinary when removing, then installing the fuel line from the carb. I haven't touched that connection since I installed a new fuel filter last summer. It is tight, I checked. Any thoughts?
Old Mar 20, 2022 | 05:40 PM
lars's Avatar
lars
Did you lubricate the threads and the back side of the flare prior to assembling it..? You also need to verify if the leak is between the flared fitting and the inlet nut fitting, or if it's between the inlet nut fitting and the float bowl.
Old Mar 20, 2022 | 06:08 PM
njvt13's Avatar
njvt13
Definitely between the flare and inlet nut. I not 100% positive, but I do not recall lubricating.
Old Mar 20, 2022 | 06:42 PM
lars's Avatar
lars
If you did not lubricate, it won't tighten up properly. Disassemble it, dry it, clean it, lube it, and re-assemble. Do not use Teflon tape.
Old Mar 23, 2022 | 09:29 PM
njvt13's Avatar
njvt13
what would you suggest for lube?
Old Mar 23, 2022 | 10:43 PM
lars's Avatar
lars
Either process-specific assembly lube or plain ol' wheel bearing grease. Clean & dry the threads and flared surfaces before applying lube.
Lars
Old Mar 30, 2022 | 07:51 PM
njvt13's Avatar
njvt13
appreciate the info, thanks.
To Fuel Filter connection leak....confused :/
