Radiator hose bulging
Old Mar 22, 2022 | 09:17 AM
Eric-'s Avatar
Eric-
Default Radiator hose bulging
Morning all,
before I change the hose assuming it is just old and beginning to bulge, is there something I should check on that could also be the potential culprit?
The hose, is the radiator to thermostat hose, it is bulging on the thermostat side. No bulging on the radiator side.
No problems with overheating.
Here’s a pic.
Thanks everyone,
Eric
73 350 TH400
edit to add:
I did a flow check, opened the cap and started the car. The coolant level dropped significantly, which means it isn’t a thermostat issue, right?
Old Mar 22, 2022 | 09:39 AM
HeadsU.P.'s Avatar
HeadsU.P.
H-m-m-m-m-m.
Python Hose Company? What did it swallow?
Never seen that before.
Old Mar 22, 2022 | 09:44 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Replace the hose. Also, with the engine cold and rad cap off, when the coolant level drops in the rad, immediately top up the rad with coolant and replace cap. You don't want air in the cooling system.
Old Mar 22, 2022 | 09:49 AM
Eric-'s Avatar
Eric-
Maybe I’m wrong about the thermostat opening.
When I first started the car the coolant level dropped. Now the car is definitely warmed up, but the coolant level is clearly back up to where it is when the car is shut off.
Old Mar 22, 2022 | 09:53 AM
fake's Avatar
fake
Air in the hose ***** it!
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Replace the hose, Its deteriorating and soft from the inside. Why even take a chance on it.
I would also check the other hoses, if soft replace them also, this includes the small hoses.
Old Mar 22, 2022 | 09:55 AM
Eric-'s Avatar
Eric-
Originally Posted by HeadsU.P.
H-m-m-m-m-m.
haha my wallet! 😅
Old Mar 22, 2022 | 09:56 AM
Eric-'s Avatar
Eric-
Roger that, will do. 👍
Old Mar 22, 2022 | 09:57 AM
Eric-'s Avatar
Eric-
With the engine hot.
Old Mar 22, 2022 | 10:12 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Either your gauge is out of whack, the stat has failed in the open position or there is no stat. Is that pic at cruising speed vice sitting in the garage? What's the ambient air temperature?
Old Mar 22, 2022 | 10:26 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Your alternator belt tensioning brace is on wrong,
Old Mar 22, 2022 | 10:33 AM
Eric-'s Avatar
Eric-
At the risk of showing my ignorance….huh?
I would have never known that that the tensioning brace was on wrong, if you had not pointed it out. However I have no idea how to attach it so that it is right!
Old Mar 22, 2022 | 10:50 AM
ralphspears
Banned Scam/Spammer
Someone post a picture for him, It is unrelated to your hose problem
Old Mar 22, 2022 | 10:55 AM
Eric-'s Avatar
Eric-
This is sitting in garage. Temp 70 degrees.
However, this does not change, at all, even while driving.
Old Mar 22, 2022 | 10:57 AM
SEVNT6's Avatar
SEVNT6
My factory upper hose did the same thing while on my honeymoon back in '81.
That's when I found out there was an early & late hose on a '76.
Old Mar 22, 2022 | 10:59 AM
Eric-'s Avatar
Eric-
It goes aft of the bolt not forward, from what I’m seeing from google pics. I almost missed it, looking right at it.
Old Mar 22, 2022 | 11:18 AM
ralphspears
Banned Scam/Spammer
Move it and post a picture for us.
To Radiator hose bulging
Old Mar 22, 2022 | 11:32 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
If I were you, I would pull the stat out and inspect. Look for small holes drilled in the top of the stat. Is the stat closed or open when you remove it? Put the stat in a pot of water and begin boiling the water while observing the stat. Does it begin to open before the water boils? Do you know if that is a stock water pump?
Old Mar 22, 2022 | 01:05 PM
HeadsU.P.'s Avatar
HeadsU.P.
I am not following your train of thought resdoggie.
Coolant does not flow to the wate-rneck. It flows away from it.
So theoretically, it should not matter if the thermostat is open, is closed or missing in action.
The bulge is past the thermostat.
I think the bulge is just fatigue, unrelated to the thermo.
Old Mar 22, 2022 | 01:19 PM
Eric-'s Avatar
Eric-
Default Temp Gauge
So I checked the temp gauge, car off, it is in the same spot as my picture I posted of the gauge.
I checked the green wire coming off my alternator, no wear, hooked up nicely.
Maybe a defective gauge?
Im going to replace the upper radiator hose, top off my coolant, and replace the cap.
I will need to diagnose my gauge issue, it seems stuck where it is.
