Heat soak issues.
Old Mar 27, 2022 | 06:58 PM
C3 Old Glory's Avatar
C3 Old Glory
2nd Gear
Default Heat soak issues.
I am looking to convert to a Holley Sniper throttle body EFI system. Heat soak is killing me on my L 82 with Edlebrock intake and carb. Any thoughts on this? 1977 L82 Original 350.
Old Mar 27, 2022 | 07:41 PM
Haggisbash's Avatar
Haggisbash
What issue are you having because of heat soak? Have you tried a heat shield between the carb and the manifold?
Old Mar 28, 2022 | 01:09 AM
C3 Old Glory
2nd Gear
Default Flooding
When car warms up, carb seems to percolate fuel. I have read that it because ethanol boils at 180°. I have not tried a heat shield. If I do, how thick can I go with spacer?
Old Mar 28, 2022 | 02:03 AM
Bikespace's Avatar
Bikespace
Can you post some photos?
Are you sure your heat riser is operating correctly, is blocked open, or removed entirely?
Old Mar 28, 2022 | 08:44 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Does your Edelbrock intake have the exhaust cross-over passage? If so, you may want to research using intake gaskets with blocking plates to eliminate the exhaust gases from heating the intake.
Old Mar 28, 2022 | 08:59 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What carb base gasket are you running? It should be 1/4" thick.
What is your timing set at? Excessively retarded or advanced timing can raise EGT's and underhood temps dramatically.
10% Ethanol fuel can boil at 200-240 degrees F.....it really depends.....I have never seen pump fuel...but it is probably not impossible.
There are thousands of Q-Jet equipped Vette's that run just fine with the stock system on today's fuel and yours can too.
Jebby
Old Mar 28, 2022 | 10:06 AM
John 65's Avatar
John 65
I had the same problem on my 77.
Edelbrock rpm performer intake and 750 Edelbrock carb. I could not restart the car when hot without holding the pedal to the floor and cranking.
I could hear the fuel boiling in the carb after shut down.
4 longer studs and a 1/4" spacer did the trick. Much better now.
Old Mar 28, 2022 | 10:12 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I will add that if you use a 1204 Fel-Pro gasket that blocks the heat riser it will lower the carb pad temp about 100 degrees.....then you just convert the choke to electric which is super easy to do on a 77' and cheap.
Jebby
Old Mar 28, 2022 | 11:08 AM
REELAV8R's Avatar
REELAV8R
My 77 did the same thing in it's stock config. What really helped was blocking that crossover heat, but until I did that I did put on a thick insulating gasket between the carb and intake and that helped a lot.
PS you don't need a choke unless you plan on running in the winter, get rid of it. I've been running chokeless for over 10 years.
Old Mar 28, 2022 | 02:47 PM
Cmurray79's Avatar
Cmurray79
I had the same issues, a 1/4 inch gasket between carb and manifold fixed the problem
Old Mar 29, 2022 | 09:11 PM
kodpkd's Avatar
kodpkd
I had the issue until I set the timing to Lar's spec.
Old Mar 30, 2022 | 07:43 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I have an L88 hood which gave me a ton of room for thicker Phenolic spacers, I like 1 inch. I new hood and paint might be less than the $4000 for the EFi when its all said and done. You need the EFI, Fuel pump, 2 filters, return lines, most likely a single plane intake, and if you want to use the timing control the either an MSD setup or the Sniper plug and play distributor....
To Heat soak issues.
