Half-Shaft Flange Fasteners
Old Mar 28, 2022 | 12:53 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Default Half-Shaft Flange Fasteners
So my '71 AIM and the '53-'82 Corvette Parts & Illustration Catalog both show the half-shaft flanges secured to the axle flanges with just bolts through french locks - no flat washers or lock washers. The half-shaft fastener kit I got from Top Flight did not have any washers for those bolts either.
However, when I disassembled my car long ago, those bolts had lock washers on them. Unfortunately, I can't access my old photos to see if the french locks were there or were missing.
I don't know if the factory originally added those lock washers (either with or without the french locks) or perhaps a mechanic later in the car's life added them (again, with or w/o the french locks).
Anyway, this inconsistency got my thinking what is best. When you folks connect the flanges (with french locks), do you add any washers or just install w/o them as shown in the AIM??
thanks,
paul
Thanks,
Paul
Old Mar 28, 2022 | 05:40 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
On my 77 which I have owed since Christ was a Corporal. It came factory with bolts/frenchlocks. no washers. Once years ago when working on the car I didn't have new french locks so I put lock washers on the bolts. Ran it like that for a few years. Next time I was working on the car I remembered to order new french locks. And then put it back. bolts/frenchlocks, no washers.
I am not a mechanical engineer. I am a mechanic. I don't generally argue with the manufacturer. they have built a lot more cars than I have.
Lock tabs or lock washers. Both doesn't make sense.
Old Mar 28, 2022 | 07:45 AM
derekderek's Avatar
derekderek
i think loctite may also be a smart addition.
Old Mar 29, 2022 | 03:06 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Thanks Guys
Old Mar 29, 2022 | 08:08 AM
GTR1999's Avatar
GTR1999
Check that the bolts are shoulder type and not fully threaded. The shoulder bolt was used with a steel French lock- which will twist before you reach torque. The shoulder bolt with SS French lock and a drop of 242 will work. The HP aftermarket flanges use grade 9 bolts and lock washers with Loctite
Old Mar 30, 2022 | 02:00 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Thanks Gary - You sure are a wealth of information!
Paul
To Half-Shaft Flange Fasteners
