What rear diff is this?
Old Mar 28, 2022 | 04:06 PM
Jd21476's Avatar
Jd21476
Default What rear diff is this?
My ‘68 has a code of CA4 2 64 (spaced out like this). I cant find anything on the decoder as to what it it.
Any help?
Old Mar 28, 2022 | 04:40 PM
PJO's Avatar
PJO
Veteran: Marine Corps
That code would be from a 1964 Corvette dated 04/02/64 CA 3.36:1 Standard Manual Transmission or Powerglide
Old Mar 28, 2022 | 04:49 PM
Jd21476's Avatar
Jd21476
So at some point somebody put a C2 diff in my C3. Would that have posi (assuming the internals are the originals or havent been swapped)
Old Mar 28, 2022 | 04:54 PM
PJO's Avatar
PJO
It is Standard no posi unless someone rebuilt it that way. CB would have been a 3:36 Posi
Old Mar 28, 2022 | 05:54 PM
Jd21476's Avatar
Jd21476
Can I have it rebuilt with posi and 3.70 gears or do I need to pull it and swap it completely?
Old Mar 28, 2022 | 06:00 PM
PJO's Avatar
PJO
Ether way you would need to remove the Differential. If you want it rebuilt to a posi would at that time have it evaluated to what additional upgrades would be needed to protect your investment.
Old Mar 28, 2022 | 07:40 PM
GTR1999's Avatar
GTR1999
You have to remove it and open it up to see what you have. It could be anything from the past 45 years in there. The 64 housings would have a tapped hole on each side of the front bracket instead of the through bolts that 65-79's had. Any 65-79 Eaton or new Eaton will fit the housing. The bearing caps will be wider if it's a 64. The 63-66 housings were narrow and the side shims are not sold in any master kits sold today. If you have an open diff it will work fine for street use, if you have the original DANA posi it was junk, it you have an 65-68 posi they weren't much better. 69- 71 were ok, 72-79 were the best posi cases and they came with junk clutches. Solid Steel clutches are on bad order for months now.
To What rear diff is this?
