Window motor
Old Mar 30, 2022 | 08:22 PM
Golferdad's Avatar
Golferdad
Default Window motor
I have the whole top end of engine off,so no wires or grounds are hooked up,I just replaced my passenger window motor but since I have nothing hooked up as far as wires to engine,how can I check this motor to see how my window works,since the battery is just a few feet away,is there a way I can check it without burning my new motor up, thanks.
Old Mar 31, 2022 | 07:23 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The window motor grounds from the body of it.....the two wires going in are up and down......clip a ground jumper to the negative and clip a positive jumper to one side or the other.....the motor should spin.
Jebby
Old Mar 31, 2022 | 08:55 AM
Golferdad's Avatar
Golferdad
Thanks,ok I will try that.
Old Mar 31, 2022 | 10:40 AM
Richard454's Avatar
Richard454
Oh- I'd get a blade fuse holder/fuse to put in line with your jumper.
A dead short in the jumper wire from the battery can easily burn your hand in a nanosecond!!! Don't ask me how I know...
A cheap one like this is fine-
To Window motor
