72 caliper casting numbers?
Old Apr 14, 2022 | 12:45 PM
sassc3's Avatar
sassc3
Default 72 caliper casting numbers?
my searching found to possibilities 2nd design or 3rd design
anybody know for certain?
tia paul
Old Apr 14, 2022 | 02:28 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Casting numbers are 5452281 inner rear, 5452284 outer rear; 5452270 inner front, 5452273 outer front. A date is often seen stamped on a upper machined surface.For your era Corvette.
Old Apr 14, 2022 | 02:37 PM
62corvette's Avatar
62corvette
Easiest thing for me to remember is that mid-67 to 72 all begin with 545.
Old Apr 15, 2022 | 01:40 PM
gbvette62's Avatar
gbvette62
65-66 First Design
Front: 5465954 & 5465952
Rear 5465902 & 5465905
67-72 Second Design
Front 5452270 & 5452273
Rear 5452281 & 5452284
73-82 Third Design
Front 5473795 & 5473796
Rear 5473806 & 5473807
Old Apr 15, 2022 | 01:48 PM
69L88's Avatar
69L88
Normally, part number progression is directionally higher but for whatever reason GM managed to retrograde the numbers for the second design, then jumped to the 547s for the 3rd design. This has resulted in being easily confused, thinking the 546s followed the 545s but clearly this is not the case.
To 72 caliper casting numbers?
