Backlash + ring gear pattern (2nd try)
Old Apr 18, 2022 | 12:08 PM
Novusuhu's Avatar
Novusuhu
Default Backlash + ring gear pattern (2nd try)
Hi everyone
I did a ring gear pattern check and measured the backlash of my 77 differential.
Here is what I got...
What do you guys think?
BACKLASH measurement: 0.009" - 0.010"
Ring gear pattern (hope these pics are good):
Old Apr 18, 2022 | 12:43 PM
Arg0413's Avatar
Arg0413
So two things going on here:
1) Pinion is two deep, this is defined by the thin sharp line at the bottom of the tooth.
2) BL is on the looser end, on a performance diff you want 6-8.
I'd reduce the pinion depth by 0.008" , and tighten up the BL and run some more patterns with a LOT of force on the gears. You also want to mix gear oil in your pattern paint to help get better patterns.
What gears are you installing?
Old Apr 19, 2022 | 09:47 AM
Novusuhu's Avatar
Novusuhu
I will not install new gears.
Only the seals and bearings will be replaced (except the pinion gear... I will leave that alone).
How do you reduce the pinion depth?
Old Apr 19, 2022 | 09:48 AM
Novusuhu's Avatar
Novusuhu
Old Apr 19, 2022 | 10:00 AM
Arg0413's Avatar
Arg0413
Okay please clarify what you're doing:
1) Setting up a new set of gears
2) Putting new bearings on an old set of gears
If you're running a pattern on an old set of gears, it's irrelevant and you don't need to make any changes. Change your carrier bearings and make sure you put the shims back exactly as they were and the BL matches the previous setup . If you don't know how to make changes to pinion depth, then you don't need to be make any changes to pinion depth...
Old Apr 19, 2022 | 10:05 AM
Novusuhu's Avatar
Novusuhu
2) I'm putting new bearings on an old set of gears.
Old Apr 19, 2022 | 11:43 AM
Arg0413's Avatar
Arg0413
There's no reason to run a pattern. When you change carrier bearings you need to take the BL before, and match it after. It should be the same or close if you put the carrier shims in the same place.
Old Apr 22, 2022 | 06:26 PM
Novusuhu's Avatar
Novusuhu
Sorry for the late comment. Been very busy with my students today and yesterday.
I thought GTR1999 replied on my thread, but the reply disappeared...
- Yes, I bought new axles. GTR asked for the measurements of the axles, which I gave.The new axles weren't perfect (as GTR replied in a previous post). But I think they will do the job (will not race the car). Future will tell...
- Yes, it are still the original gears from 1977.
Do you guys know how I can remove the old races and bearings that are installed on both sides of the posi. unit? It is best to replace them, when the unit is out the case?
Old Apr 22, 2022 | 07:06 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Removing those bearings is a real pain. It requires a press and the correct bearing remover tool. Not sure I would do it with the gear on. You can not afford even one chip on those gear teeth. And you already have it all clean and assembled. Still a PITA for a first timer like me.
So why did this come apart? Leaky seal? Just do that.
Spritz the bearings with some light oil and see if they spin smoothly. Clean and examine closely and look for wear marks, pitting etc. Did they make noise?
If they pass those tests I am not sure I would mess with them.
Your choice.
BTW your diff currently looks very clean, and dry. Too clean to install actually. I would reload those clutch discs and soak them in diff oil as they go in. Or they will make noise for a long time.
Old Apr 22, 2022 | 07:41 PM
Novusuhu's Avatar
Novusuhu
Your choice.
I have a press at home. What the correct tool to remove them?
Old Apr 22, 2022 | 07:50 PM
69L88's Avatar
69L88
One of these. Be sure to get a good quality one - it takes a LOT of force to remove the race from the carrier and there is not a lot of contact area between the puller and the race.
Old Apr 22, 2022 | 09:35 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Save your old races, and you can dremel them to a loose fit, cut off the needle bearings, and then use them as a press tool to put the new bearings on without damaging them.
Old Apr 23, 2022 | 01:01 AM
kossuth's Avatar
kossuth
Ditto…. I have a milk crate full of the old inners of various bearings I’ve replaced over the years. More than once they have come in handy.
To Backlash + ring gear pattern (2nd try)
