Engine upgrade stalled
Old May 6, 2022 | 03:23 PM
Steve Kistler's Avatar
Steve Kistler
Default Engine upgrade stalled
I recently upgraded my 79 L82 which was running and driving fine before I did my upgrades. I installed a set of estreet heads a set of long tube headers and a stall converter. I already had a stage 3 cam in the car . Herein is the reason for my questions. After adjusting the valves and setting #1 cylinder at tdc on the compression stroke and assuring the rotor was pointed at #1 cylinder I attempted to start the engine. A very large backfire occurred making me believe I was 18o deg out but I was not. Could someone share some possibilities please. Thanks
Old May 6, 2022 | 03:57 PM
BKbroiler's Avatar
BKbroiler
One or more valves are set too tight keeping the valve open while the cylinder fires.
Old May 6, 2022 | 04:37 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Stage 3 cam really means nothing to me. Everyone has their own version. Is this a solid flat tappet cam or a hydraulic? What did you set the valves to cold lash, hot lash, zero lash? How did you find TDC? Did you make sure that plug wire #1 is where it needs to be on the cap?
Old May 6, 2022 | 04:53 PM
Steve Kistler
sorry for any inconvenience but I broke the cardinal rule and only checked wiring twice.great news is put the wires in proper place and fired right up.
Old May 6, 2022 | 08:22 PM
Golferdad's Avatar
Golferdad
I’m in the same process,trying to get everything wired and hooked up,so,maybe a week or two at the most,before I try to crank it,I have my headers on the engine,and will have to take it to a muffler shop to have them welded,and it’s about a foot off the ground now,but hey are about 2-3 inches below my existing pipe,and actually a inch or so below the pan,what kind of ground clearance do you have,oh,I have a 1981.and I replaced e street heads,Edelbrock intake,AVS2 carburetor,and HEI distributor,and headers. Thanks
Old May 6, 2022 | 08:25 PM
Golferdad's Avatar
Golferdad
They are about 2-3 inches below existing pipes
Old May 6, 2022 | 09:12 PM
Steve Kistler
actually I bought ceramic coated flowtech full length and they match almost identical to my previous true duals that run through the trans crossmember. I am taking mine to a shop next week to go fro 2 1/4 to 2 1/2”
Old May 6, 2022 | 09:24 PM
gjohnson's Avatar
gjohnson
Those headers hang to low.You need Corvette specific
Old May 8, 2022 | 07:11 PM
Steve Kistler
After engine upgrades are you supposed to use premium gas?
Old May 8, 2022 | 07:16 PM
kossuth's Avatar
kossuth
That is engine specific. If your static compression is up around 10:1 I would say its advisable but there is some much else that factors in. Timing, combustion chamber shape, AF ratio, camshaft parameters etc.
Old May 9, 2022 | 08:02 AM
augiedoggy's Avatar
augiedoggy
That completely depends on you compression ratio and what it is with your new heads? if they were 64cc chamber heads theres a good chance you may need at least 89 octane but it depends on other things like the quench and chamber design. and your dynamic compression ratio which is determined by the cam which can either increase or bleed off some compression. there are calculators online to help determine this stuff, thats how I did it for my build.
Old May 9, 2022 | 08:23 AM
Golferdad's Avatar
Golferdad
No,just get me some 22’s.lol
Old May 9, 2022 | 09:30 AM
augiedoggy's Avatar
augiedoggy
I now your kidding but in case your not, keep in mind the bigger tires will be like going to weaker diff gears, the car will likely deliver less power to the ground than it did before the upgrades then. a couple inch difference it tire size makes a big difference in gear ratio.
Old May 9, 2022 | 09:41 AM
REELAV8R's Avatar
REELAV8R
What did you end up with for a cam? That will probably have the largest impact in your case as far as engine specs. Any Idea what the quench ended up being?
Having a higher stall converter will help. What is the rear gear ratio? Cooling system performance will make a big difference too.
Get the timing set up right and the carburation dialed in will make a huge difference in dirveability as well. Use Lars" papers to get this right. Having Lars rebuild your carb would be nice performance upgrade, unless you want to tackle it yourself. Then I suggest using Cliff Ruggles book on the subject. you'd be amazed at the difference a properly dialed in carb can make.
There are a lot of factors involved in what octane to use. If you just want to be safe use the highest available at the pump.
Old May 9, 2022 | 11:53 AM
derekderek's Avatar
derekderek
and the headers. we need to remember the corvette engine is lower than all others. our front pulley is just above the rounded crossmember that on all other cars is under the oil pan.
Old May 9, 2022 | 02:39 PM
Golferdad's Avatar
Golferdad
Yea,I was kidding.,I would raise the engine before I would put taller tires on. I haven’t dropped to the floor yet,but I think I might have 3 inches of ground clearance.
Old May 11, 2022 | 10:08 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I urge you to get the correct headers now......you will have nothing but grief with those.
Jebby
To Engine upgrade stalled
Old May 11, 2022 | 10:03 PM
Golferdad's Avatar
Golferdad
Thanks Jebby might be my only choice,so,I’m assuming hooker or Hedman headers.
Old May 14, 2022 | 10:06 AM
Steve Kistler
This and other plugs look like this after 4 heat cycles. What is the verdict?
Old May 14, 2022 | 11:30 AM
derekderek's Avatar
derekderek
steve. OP. what do you have for ground clearance? and for comparison's sake, fender lip to ground at the center of the tire Golferdad. if you can't find a number on those headers to tell what they are for, sell them to anybody that has a small block in anything else. these cars hit the ground enough already.
