Brake bleeding survey?
Old May 11, 2022 | 03:02 PM
  #61
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by kodpkd
I really do understand how brakes work,,,,,,, but that isn't the question.
I ask, if someone got a C3 manual brake car, would he be more or less likely to be unsatisfied with the perceived braking of the car?
If someone is working to make the brakes better on his C3, would be easier to make a boosted brake car good enough.
Depends on how hard they like to press on the pedal.......
Would it be easier to make a power brake system stop better? Maybe.....but it will not solve the issue if there is one. If there is an issue...it needs to be addressed, power brake or not.
Jebby
Old May 11, 2022 | 08:12 PM
  #62
60 SHARK's Avatar
60 SHARK
Your question #1,,, Less likely to be unsatisfied with the perception.
Your question #2,,, No.
.As Jebby stated, its a simple system,
Old May 11, 2022 | 08:30 PM
  #63
kodpkd's Avatar
kodpkd
I believe there is much more effort and frustration trying to make the manual brake cars to brake well, than the power brake cars.
It's not that difficult to get the power brake cars to stop.
Old May 11, 2022 | 09:03 PM
  #64
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Because you believe it doesn't make it true. And its not that difficult to get manual brake cars to stop. Believe it!
Old May 11, 2022 | 09:24 PM
  #65
Bikespace's Avatar
Bikespace
I had a manual brake car I couldn't get bled until a friend helped me with a power bleeder. That was over 20 years ago.
On the C3s (both power brakes), nothing worked for me except the Motive power bleeder.
For the act of bleeding, there is NO difference. However, due to the different dimensions of the MCs, the power brake MC can push (slightly) more volume of fluid and may be (slightly) more able to tolerate a few remaining air bubbles. If you get all of the air out, which should be your goal no matter how you do the bleeding, there is NO difference.
In my quest to remove all vacuum hoses from my cars, manual brakes are next. Maybe I'll remember to update if I notice a difference, but there won't be a difference, at least in the bleeding step.
Old May 11, 2022 | 09:27 PM
  #66
kodpkd's Avatar
kodpkd
It's called an opinion.
That's why there more threads about making brakes work correctly than any other system.
Old May 12, 2022 | 12:04 AM
  #67
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Motive power bleeder and speedbleeders. Yeah, it's redundant, but it works for me. I don't have to keep adding fluid as I go.
Old May 12, 2022 | 07:01 AM
  #68
Alwyn678's Avatar
Alwyn678
Originally Posted by wwiiavfan
Take it to a competent Corvette shop.
It will lighten your wallet, but add years to your life that all the other methods remove.
Old May 12, 2022 | 07:08 AM
  #69
Mr D.'s Avatar
Mr D.
I have been using a Motive pressure bleeder for the last 10 plus years and have zero issues bleeding brakes by myself.
Old May 12, 2022 | 10:09 AM
  #70
71 Green 454's Avatar
71 Green 454
I think a Motive pressure bleeder would be the best for bleeding brakes. Since my brake pedal pumper (wife) retired from that job, I've been using a Mighty Vac to bleed and change brake fluid on my manual brakes '71. I've also used it on 2 MB's with power brakes. I always get a full pedal.
Old May 12, 2022 | 01:06 PM
  #71
F4Gary's Avatar
F4Gary
If the engine isn't running, they are all manual, no assist, brakes.
