Ok. But you still have a carb pad to mount the carb. Isn't that blower the same clearance as a Intake Manifold? IDK
Those bigger diaphragms have a slightly longer stroke to the pump arm.
Not sure I'll have to give it a close look - I mentioned it in case it added something to the equation that would make a difference.
