Converting to roller cam
Old May 12, 2022 | 11:32 PM
Ethan_Hensley's Avatar
Ethan_Hensley
Default Converting to roller cam
Hey guys, so I’m going to convert to a roller cam, so I was wondering what the equivalent to comp’s 305h 253/253 and 110 flat tappet would be in a roller. Would like to stick with comp.
Old May 12, 2022 | 11:58 PM
Ethan_Hensley
I’m looking at Comp 12-470-8 252/252 duration over the latter 253/253
Old May 13, 2022 | 08:43 AM
gkull's Avatar
gkull
Really! How many cubic inches do you have? That is something like what Skip White puts in a 434 ci Small block to get 650 HP. 383 ci run the best with about 236 intake duration @ .050 350 ci about 232 I. with big matching heads like the AFR 195 - 210 cc
Old May 13, 2022 | 09:33 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
What's your engine specs and intended use? We can go from there.
Old May 13, 2022 | 10:29 AM
Ethan_Hensley
383 forged internals, and ported AFR 195s mostly to the drag strip and occasionally rumble the streets
Old May 13, 2022 | 11:06 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Old May 13, 2022 | 11:30 AM
gkull's Avatar
gkull
what kind of transmission and stall? Any ideas about the compression? What intake?
Back when I had a 383 and 3500 stall consistent 11.70 with Goodyear slicks 4.11 rear end I went with a solid roller to NOT be rpm limited like a sub 6500 rpm H-roller. I was shift at 7200+ rpm rev limiter set to 7500. All this with AFR 210 heads and 11ish C/R team "G" single plane with wood spacer custom Comp cams equivalent to say a Extreme energy 242/248 if you used the .200 lift numbers
Old May 13, 2022 | 04:07 PM
Ethan_Hensley
Whats the real difference between the solid roller and hydraulic roller?
But the solid roller id probably go with is
Comp 12-705-8
it runs 255/255 at .050 with a .575 lift
Old May 13, 2022 | 10:29 PM
gkull's Avatar
gkull
Comp 12-705-8
You did not answer a few things. going to a massive cam might make it sound bad, but it's self defeating to have over cammed
Read up on cam types
To Converting to roller cam
