Anyone regret using synthetic fluids
Much easier & smoother shifting than with conventional gear oil. Especially in cold weather here in the Northeast. Been over 12 years
Thousands of miles, trips to the drag strip, it has worked in my M21.
Put dino gear oil back in. Been shifting fine now for the last 10 years. The syn was to slippery. Synchro's didn't grab.
NEVER again.
NEVER again.
I am sold on syth engine oil and remember the "leaks" oil when switching complaints.
I have a 2004-r I am going to rebuild, upgrade and I am hesitant to go synth.
This comes from using a few quarts in an old th350 that used standard type 3 dex for its entire life.
I noticed a subtle change in shifting and feel.
(You can't drop a bomb like that without explanation!) ;-)
I went with Penzoil Platinum Full Synthetic 10w30 which is ILSAC GF-6, but only because I found it a tiny bit cheaper than Castrol Edge 10W30 which is also ILSAC GF-6.
-I'll happily use either one.
I bought Amsoil synthetic for my 4L60e, but I'm tired of paying the Amsoil tax and looking for something else when I refill it (radiator swap.))
Synthetic wheel bearing grease seems like a no brainer to me.
I also use Motul DOT 5.1 brake fluid; I like all the benefits of modern fluids science.
Differential is the only place where I'm scared of synthetic...
I've seen too many people complain about slippage and I honestly don't understand what's required, it's one place where I'd LIKE to embrace modern synthetics, but I just see too many threads where it caused issues and going back to a more OEM fluid and the original GM additives solved the issue to try to experiment here on my own car... (Plus I don't feel like I fully understand differentials, so naturally more fear there...)
Adam
https://bobistheoilguy.com/forums/th...ar-oil.119570/
I use the same Red Line GL-4 in my manual transmission and C3 differentials. The car seems to shift better. I haven't run into the "too slippy" issue that @4-vettes mentioned.
On every car I've tried, synthetic gear oil leads to smoother shifting, and in one case a lower transmission temperature. Just be sure to use the specified rating.
I have however read numerous times others have had this issue. Perhaps it's the difference between GL4 and GL5.
I do not know. I know my modem 6 speed loves the synthetic. My old 4 speed does not.
My John Deere garden tractor have been using Mobil 1 for 20+ years, and I mow a lot of grass. Engine still functions great. Doesn't use any oil at all. Briggs Vanguard. Every year for the last 10 years I keep saying I should replace it, but there hasn't been a compelling reason.
I mix a bit of STP with the required oil in the dif and trans and never had a problem.
Now mixing or additives are probably a NO NO. but I used to get STP by the gallon for 3.50 if I brought the container.
Still use it.
Dom
Adam
It shifts quicker.
It will kickdown with little thottle.
Seems the stall rpms have increased?
Definitely different from such a little amount of syn overall?
I am worried about clutch and band slippage.
