Cock tailing old gas
Old May 20, 2022 | 05:54 AM
JiminSTLouis's Avatar
JiminSTLouis
Ethanol Free Gas
Old May 20, 2022 | 07:59 AM
fake's Avatar
fake
After 77 years i will not use fuel treatments. Run the tank dry on all small power equipment and buy high test to run for all! As far as car goes and at todays prices siphon off at the begining of the season and use in your least worthy car!
Old May 20, 2022 | 08:03 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Ethanol free is too expensive to even bother around here. It was $10 back before the Biden increase. I should go look now, its probably closer to $15 I would guess.
I dont understand why we are still using it in this country
Old May 20, 2022 | 08:24 AM
Dirty Dalton's Avatar
Dirty Dalton
Can you spell 'Lobbiest' (hmmm, I don't know if I can spell it...). We've the finest Gov $ can buy.
Old May 20, 2022 | 08:25 AM
Rescue Rogers
So very true.....I guess we could have someone sign and executive order, that seems to work when you dont get what you want
Old May 20, 2022 | 10:24 AM
SEVNT6's Avatar
SEVNT6
Ethanol is hygroscopic. Definition:
A substance able to absorb moisture from surrounding areas.
So ethanol literally sucks......
Old May 26, 2022 | 08:10 AM
fake's Avatar
fake
I **** tailed my 1993 gas a mix of non ETHANOL! ( i ASSUMED MOBIL 1 93 OCTANE WAS ETHANOL FREE) I did it a gallon of the stale gas with my other cars. The 77 Corvette started quicker and had a ton of more *****. the other vehicle ran okay and showed no change of performance even though it always was filled with off brands 93 octane. I will not mix it in my Lexus for i do not need a problem with my wife car. So far **** tailing has been fine. A not i used some to clean some paint brushes and this cleaned the brushes with one dip of the brush!
Old May 26, 2022 | 01:00 PM
Kerschmolar's Avatar
Kerschmolar
Ethanol content should be posted on the pump. Check pure-gas.com for locations offering no ethanol in their gas. Was $5/gal in January; now up to $7/gal..
Old May 26, 2022 | 04:21 PM
Rescue Rogers
was told our local Haffners has it at $13 per gallon for 100 octane......hmm
