1978 corvette pinion seal replacement.
Old May 17, 2022 | 07:38 PM
cagotzmann's Avatar
cagotzmann
Default 1978 corvette pinion seal replacement.
So the rear diff has a small leak at the pinion area, I was looking at replacing the seal.
I found some douments on procedure, which seemed simple enough , but wanted to confirm a few things.
1. the yoke attached to the pinion gear is torqued to ~ 11-15 in lbs. ( planned on marking the current poisition and tighen to the same location.
but what holds the nut in place. theres no cotter pin and the torque is very light. I was thinking of using lock tight on the treads ?
Any one guide to a procedure. ? Is there a measurement that needs to be re-set etc.
Thanks....
Old May 17, 2022 | 08:06 PM
69L88's Avatar
69L88
The 11-15 in-lb torque value you reference is for the preload of the pinion bearing, NOT the torque value for the nut.
The nut is a self-locking design. If you look closely, you’ll see the outer end is not round.
Unless the differential has been rebuilt with a solid sleeve in lieu of the crush sleeve, you will not need to worry about torque values. Mark the nut position relative to the pinion threads and remove it. Remove the yoke (it most likely will require use of a puller). Note the position of the flange of the seal relative to the housing. It should have an 1/8” gap. When you install the new seal, be sure to keep the 1/8” gap. Do NOT attempt to drive the flange to contact the case. This is important.
Thoroughly clean the mating surface of the seal land and the splines on the pinion and the yoke. Apply a small bead of sealant (Permatex #2) to the seal land and the seal and carefully drive it into position. Do not “****” the seal during the process. Apply a light coat of the sealant to the splines of the pinion and the yoke. Do not apply so much that the sealant mushes into the bearing. Install the yoke. Apply red loctite to the nut and tight to the witness mark you made at the start. DO NOT overtighten.
Old May 17, 2022 | 08:28 PM
interpon's Avatar
interpon
Mine went a hair past the mark..to get proper pre load torque..5-10 used..i got 5 and stopped
details here to your questions and specs for used bearings
https://www.corvetteforum.com/forums...-advice-3.html
To 1978 corvette pinion seal replacement.
