Help
Old May 18, 2022 | 11:36 AM
Martini2017@'s Avatar
Martini2017@
6th Gear
Default Help
I have a beautiful 1977 Corvette, i went out to eat, stopped at a gas station and she refused to go in reverse. She will only drive forward. Any suggestions on what the problem is?
Old May 18, 2022 | 11:56 AM
kansas123's Avatar
kansas123
Automatic or stick
Old May 18, 2022 | 12:15 PM
Martini2017@
6th Gear
Originally Posted by kansas123
Automatic or stick
Automatic
Old May 18, 2022 | 12:38 PM
ctmccloskey's Avatar
ctmccloskey
Welcome Martini2017@ to the Corvette Forum! You are in the right place to get good answers and advice on how to keep enjoying your Corvette! The volume of experience available here on the Corvette Forum is absolutely amazing!
The more information you "share" with us here at the Corvette Forum the more likely that someone will be able to assist you in solving the problem with your beautiful 1977 Corvette!
On your "Public Profile" page there is a place where you can enter all the details you wish to share regarding your Corvette. Often when there is a question we go there looking for more details that are frequently in the Postings. Things like any modifications and changes from the original platform are very handy for we the people that want to try and help you. The question regarding whether you have an Automatic or a Four speed is a great example. It is also helpful to know how long you have owned this Corvette and just how mechanically inclined you are can also be helpful. All of us here appreciate having a good running Corvette to go out cruising in and we are happy to try and help you get your problem solved. The more you share the better regarding the specifics of your Corvette as this makes it easier for people who have had similar problems recognize the problem right away.
I myself and re-installing a new fuel tank into my 1968 Corvette this afternoon as the weather in my part of the country is going to get very warm over the next few days. After reading up on this here on the Forum I have learned a few tricks from others to make the job easier and get better results without to "re-inventing the wheel" so to speak. This Forum is the very best source of information for helping us keep our Corvettes running at their peak for the cost of reading a bit of information written by other Corvette enthusiasts.
Best regards,
Chris
Old May 18, 2022 | 12:40 PM
OldCarBum's Avatar
OldCarBum
Sounds like the shifter linkage has become disconnected.
I would tow it home, lift it up and see what is going on between the linkage and the transmission.
Old May 18, 2022 | 12:42 PM
Martini2017@
6th Gear
Best regards,
Chris
Thank you i have a very beautiful car and ive got to fix this, enjoy your day, the weather is very hot today here in Alabama and the birds are singing
Old May 18, 2022 | 12:45 PM
Martini2017@
6th Gear
I think because im a 58 year old female, its wowing me i have to fix the problem, i was raised guys fix cars. But lately all i get is ole cooters wanting to buy it for 5 or 6 thousand with it not fixed and i dont like that.
Old May 18, 2022 | 12:46 PM
wwiiavfan's Avatar
wwiiavfan
Agree, if you don't have anyone to sit in the car with the brakes on, fiddling with the linkage can get a little sketchy. Even with someone, it can be sketchy.
Old May 18, 2022 | 12:58 PM
derekderek's Avatar
derekderek
does it go into park? if so and it also goes into drive and drives reverse may be dead.
Old May 18, 2022 | 02:06 PM
69L88's Avatar
69L88
See if there is a local Corvette club that you could reach out to.
Old May 18, 2022 | 02:46 PM
interpon's Avatar
interpon
have you checked the fluid level?
Old May 18, 2022 | 03:15 PM
Greg's Avatar
Greg
Just another Corvette guy
If the car shifts into drive I don't think it's going to be a linkage problem.
Did the car ever happen to sit for a long period?
If it did sit for a long period it's not uncommon for the reverse piston seal to dry up and then you lose reverse. You can try placing the shifter in reverse and revving the engine up a bit to see if it will engage. If it does, it's that reverse seal.
Before doing this, first check to make sure your fluid level is correct as interpon says. If this test proves positive and you're on a budget, you can try changing the transmission fluid and filter and adding a good aftermarket transmission seal conditioner. "sometimes" these will soften the reverse seal and it will work again. It's not an instant cure, you may have to put a hundred miles on it to get the desired results but it's worth a gamble for the few dollars involved. I have had luck with this procedure in the past. Otherwise it sounds like it may be time to pull the transmission and have it rebuilt. Upside is it's just a Turbo 350 and parts are not too expensive. Any trans shop can do it.
Cheers, Greg
To Help
