Speedometer cable lube
Old May 25, 2022 | 11:42 AM
Whets's Avatar
Whets
Navigator
Default Speedometer cable lube
Curious to know what the best products and methods are to lube an 81' automatic trans, speedometer cable.
Thanks Adam
Old May 25, 2022 | 11:55 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Graphite is the ticket. Stay away from grease.
Old May 25, 2022 | 11:46 PM
Eliredandblack's Avatar
Eliredandblack
Look at Willcox Corvette Technical Page for instructions, I don’t think they like graphite. I found some grease on EBay specifically for cables.
Old May 27, 2022 | 05:51 PM
HeadsU.P.'s Avatar
HeadsU.P.
The cable I bought recommended "gun grease". It can take the outdoor environment & heat of the exhaust.
Those cables have a spiral pattern to them, almost like an auger. And that design goes up hill. If you use anything too thin, the auger will eventually "pump" lube all the way up the cable sheath or housing, and into the back of the dash where it gums up the speedometer.
When you grease the cable, only lube the bottom half, light coating.
To Speedometer cable lube
