Hello guys I've a new problem with my C3. I've had some problem with it for the carburation and my mechanic has needed to change my "quick fuel" carburetor with new one, replace all the cables sparks and upgrade ignition points to an electronic. Now the car go very well with a great minimum but some time it loses power for a second or two going sobbing, during this second the radio stay on and all the light stay on. Normaly this doesn't happen at high RPM or when I do a full throttle acceleration, this happen with normal drive condition and during a costant acceleration. I use the car only in the weekend and for the last 3 exits this doesn't happen anymore but today has started another time, in one hour of exit it's happened 3 or 4 times. Before the works this never has happened, so I think that the carbureator or the ignition upgrade could have some problem, but my mechanic dosen't have idea. Let me say that for the USA cars he is one of the best in Italy so I can't find another mechanic
Someone of you have an idea?
This sounds like an electrical problem rather than carburetor since you have good acceleration and high rpm. Does it happen at idle, or only when moving? Do you know the brand of the electric ignition? Pics of the distributor and carburetor may help diagnose the issue.
Hello, thanks for reply, this happens only when the car is moving the carburetor is another "quick fuel" brand new I think 600cfm, tomorrow I'll take a photo. For the distributor I don't know the brand, but tomorrow I'll try to discover it and take some photos. So for you is impossible that could be something wrong in the new carburetor?
What year Corvette are we talking about?
Is the engine of a similar age as the car or is it a more modern replacement with some computerized components?
Because the engine idles and accelerates fine with good high rpm characteristics, I don't think you have a fuel problem. You also mentioned, "during this second the radio stay on and all the light stay on" which sounds like an electrical issue. Can you explain this a little more?
The car is c3 '72 and is all original, the motor match the chassis. I've try to drive with radio on for understand if the problem was a lose of electricity, but when it happen the radio and the lights works well. The only thing that worry me is that with the electronic ignition I still have the resistor wire connected to the coil and I know that with the electronic ignition normaly is needed a full 12v, can be this the problem and if yes why this happen sometime and not continuously.
Hopefully someone more familiar with electronic distributors can chime in as my cars only use mechanical points. That said, I believe a resistor is not to be used on an electronic distributor and as a component heats up the resistance gets higher. Your resistor wire may be the source of your issue, but I'm just guessing.
Perhaps my understanding of the issue is incorrect but my as I’m reading this it sounds like the car is coughing and sputtering but not outright dying. If thats the case take a good hard look at the fuel system. Check the fuel sock in the tank. Make sure your rubber lines aren’t breaking down from ethanol and age. Make sure your fuel pump is making the required fuel pressure.
If this is an ignition related cough and sputter then until it dies outright its gonna be hard to find unless a visual inspection shows you a bad wire. Might also be an ignition switch.
The car work well, it can work well for hours going in city or in highway, but sometimes during constant acceleration lose power such someone switch off the key or stop the fuel, but is for one or two second and the car doesn't shutdown, after this all return to work well. For me is one of the two components that the mechanic have change, the day that he have make this changes I was with him and for me this is happend after the carbureator, but it's new and I can't understand what inside a carbureator can give this type of problem, so probably is somenthing in the new ignition system and I have the suspect that, as you saied, will be difficult find the problem before that the part will die
2016 C3 of Year Finalist
I had a simikar issue and it was a bad ignition switch. Yours may need a slight adjustment. Check your engine to frame grounds and the grounds for the battery. Could be corrosion is causing a power loss enough to shut down the iginition system
