Budget Engine Options?
Old Jun 20, 2022 | 01:40 PM
augiedoggy's Avatar
augiedoggy
Originally Posted by ClashforPeace
Hi all, I have a ‘76 with a stock 350 in it. It was rebuilt a few years back, but I really want more power. The stock 180HP is just not enough. The torque figure is alright, and does help to give it some pep, but I would still like a bit more. I thought about maybe doing some upgrades, but I would think that doing so would ruin any chance of it passing emissions.
So, that leaves me with needing to replace the engine (unless some of you guys who are much smarter than I have any ideas). What engine would you recommend for someone on a budget? And are there maybe some engines out there that aren’t fully dressed that I could use some of the parts I already have on (i.e. carb, fuel pump, etc.)?
Any help is greatly appreciated!
you would have to pass those same "emissions" regardless of engine displacement though right? you already have a rebuilt sbc 355. New heads and you have an engine that can produce much more power. Im not sure I follow how you think you need to replace the motor for smog testing? as others have mentioned if its your exhaust system that cant be changed your engines compression ratio and or displacement wont matter much because the exhaust will be the power bottleneck preventing the engine from breathing and making more power...
In that case,
rear end gears is good place to start and a 4 speed trans will give you the benefits from the new rear gears without the high rpm tradeoff at highway speeds.
Old Jun 20, 2022 | 01:54 PM
augiedoggy's Avatar
augiedoggy
Originally Posted by Cmurray79
I’m making about 250 net with an edlebrock performer intake, cam, 2.5 inch dual exhaust, Lars timing tune. Stock heads and pistons. You arnt gonna get much more than 250 without new cam and heads. You arnt gonna be making big boy power 400+ without a full rebuild and blueprint, and at that point a crate engine is often more financially sensible
Why not though? Im making 400 now with a cast steel, flat top, shortblock 355 with a mild cam and better flowing 64cc heads to boost the compression to 10 to1. You can build an engine to make 400hp at lower rpms vs needing forged internals that rev to 6500rpm. We dont know what pistons he has now but as Reelav8r can atest to you can still make decent HP with the dished pistons and good matched heads. It doesnt have to cost a fortune either. I just replaced my old dart heads with some generic AT racing aluminum casting I bought for $300 for the pair, At about $700 assembled and ported for the pair I noticed a large increase in performance with these alone vs the iron dart heads I had. you can buy these chinese heads assembled by AFR and sold as the enforcer line for a pretty reasonable price too.
