Strut rod bush sizes
Old Jun 18, 2022 | 06:04 AM
riverracer au's Avatar
riverracer au
Default Strut rod bush sizes
removed my trailing arms from my 72 today and noticed that the rubber was squeezing out of the mounting area around the strut rods..
so I go to my spares box with lot of new (just in case) parts that i have amassed over the years, yep, got a set of 4 new bushes....
but they wont fit, they are 1-1/4 dia... loose as because the strut rods have the larger 1-3/8 dia holes in them
worked out that they are the 75-82 rods....
is this a normal swap out? are they the same length? cause no problems?
I've had the car since Oct 2010, and only noticed when pulling it all apart.
Old Jun 18, 2022 | 06:38 AM
Mr D.'s Avatar
Mr D.
Yes, they are the same length. Somebody in the past swapped them out with the later model style.
Old Jun 18, 2022 | 08:56 AM
Mooser's Avatar
Mooser
Sometimes you can even get one of each
https://www.corvetteforum.com/forums...my-1970-a.html
M
Old Jun 18, 2022 | 09:54 AM
kodpkd's Avatar
kodpkd
I had the same issue with my 68. Ordered the larger ones, sanded and painted the rods,,,, good as new. Easy peasy.
Old Jun 18, 2022 | 11:18 AM
GTR1999's Avatar
GTR1999
Check the fit of the rod end in the support, sometimes the 63-74 supports are tighter in the "corners" and may cause a bind in extreme travel, simple file or burr will clean it up
Old Jun 18, 2022 | 07:57 PM
riverracer au
looks to be plenty of clearance and there are no marks or gouges on rod ends or spindle support.
is it true that you should put a little bit of lithium grease under the inner end caps before installation?
some forum posts that i have been reading up on say yes others say not needed...
To Strut rod bush sizes
