Fuel Regulator install
Old Jun 21, 2022 | 05:19 PM
andresmadero's Avatar
andresmadero
Cruising
Default Fuel Regulator install
1975 C3
350 sbc
Avs2 edelbrock carb
Mechanical fuel pump
Guys I need help figuring out where to put a bypass fuel regulator Holley 12-881.
my setup:
Tank>Pump. From the pump to lines come out. One is the return line back to the pump. The other one goes to a filter and then to the carburator.
This regulator has 2 in/out Ports and one labeled as return.
what should I do with the return port out of the regulator ?
A. T join with the current return line?
B. Plug it and just put the regulator between the carb and the filter ?
Old Jun 21, 2022 | 05:38 PM
augiedoggy's Avatar
augiedoggy
I used a holley type regulator just like yours with no return line on it myself... after the fuel pump. the edelbrock carbs like less than 5psi I think I had mine adjusted to like 4 when I had one. I used the input from the bottom now with my quick fuel carb.
