Hurst comp plus install, not a clue
Old Jun 25, 2022 | 04:23 PM
azhodge's Avatar
azhodge
Default Hurst comp plus install, not a clue
I have a 1968 327 with a muncie m21. I purchased a new hurst comp plus. Exhaust runs down the middle. I will be lying on my back. This looks hard as hell to get done, console is out. Do I have to remove an exhaust pipe and or cross member?? any sage advice on removing the stock shifter and installing the hurst would be greatly appreciated. thanks Atlanta
Old Jun 25, 2022 | 04:44 PM
Vette5311's Avatar
Vette5311
Unless your car was an automatic I think your cross member is welded in. Not a fun job but we’ll worth the effort. Once installed and adjusted properly you will love the way it shifts.
Old Jun 25, 2022 | 06:07 PM
sunflower 1972's Avatar
sunflower 1972
I found this:https://www.corvetteforum.com/forums...procedure.html
Old Jun 25, 2022 | 10:00 PM
texas_c2's Avatar
texas_c2
I just installed a hurst on my 66. Yes the driver side exhaust had to come out in my case. I also cut down the plastic alignment pin before installing so it just cleared the levers. Then I had clearance to pull it out once the shifter was installed. More work than I thought, but I was happy with the result.
Old Jun 26, 2022 | 08:25 AM
sleepchamber's Avatar
sleepchamber
Lots of youtube videos on setting these up. Its easier with the trans out but doable while still installed in the car. Much easier to work with than the stock shifter though.
To Hurst comp plus install, not a clue
