C3 diff issues?
Old Jul 3, 2022 | 05:36 PM
flat tappet's Avatar
flat tappet
Default C3 diff issues?
Anyone with a 76 have diff issues that needed to be repaired?
Popular Reply
Jul 3, 2022, 10:04 PM
GTR1999's Avatar
GTR1999
Sure I'll play.
1976 original corvette differential issues
  1. Abuse- broken parts inside
  2. posi case cracked
  3. ring gear bolt backed out, gouging the posi web side and the LH wall.
  4. axles worn down, crashing into the lip over the seal, grinding it down into the seal, causing large oil leak and possibly wrecking the housing. If standard axles were installed the back side of the ubolts cut into the housing ears
  5. pinion seal leak- not sealing the splines, ripping the new seal, using a cheapo seal to save $5
  6. broken snowflake clutches in a manual car with 370-411 gears
  7. Elongated posi cross shaft holes causing excessive axle endplay
  8. broken cross shaft bolt, possibly blown out the side of the posi case
  9. pinion crashing into the posi case after someone rebuilt the diff or just replaced the pinion seal and didn't know about checking it for clearance.
  10. wrong size bolts used in the strut rod bracket or cover plate for the spring, cracking the housing causing an oil leak
  11. Probably the best one that could include most of the above- inexperienced and production shop service.
Old Jul 3, 2022 | 08:48 PM
sunflower 1972's Avatar
sunflower 1972
Could you elaborate on the "issue's" ?
Old Jul 3, 2022 | 10:04 PM
GTR1999's Avatar
GTR1999
Sure I'll play.
Old Jul 4, 2022 | 07:07 AM
flat tappet
So far.......my only diff issue appears to be rear wheel movement when I had it up on the rack for a front end alignment.
The mechanic was able to move the right rear wheel in/out 1 inch(or more) and a small amount on the left. Not the wheel bearings. as it slides in/out on the drive shaft.
No noise and no fluid below the diff.
Perhaps the axle shaft worn....that goes from the yoke into the diff?
Old Jul 4, 2022 | 07:17 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Ve broken teeth ona 3.70 older diff, have another 3.55 that is going, but the current 4.11runs strong
Old Jul 4, 2022 | 07:21 AM
BKbroiler's Avatar
BKbroiler
See Item #4 in GTR1999's post above.
Old Jul 4, 2022 | 08:26 AM
flat tappet
Guess I will need the shafts betwwen the yokes and the diff....at the .very least
Old Jul 4, 2022 | 08:29 AM
flat tappet
Guess I am going to need these, at the very least.....C3 Corvette 1968-1979 Differential Side Yoke | Corvette Mods
Old Jul 4, 2022 | 08:42 AM
interpon's Avatar
interpon
suggest looking at this
https://www.corvetteforum.com/forums...ay-advice.html
the chore will be to find the correct hardened axles..
Old Jul 4, 2022 | 08:45 AM
Bikespace's Avatar
Bikespace
Take a look before you buy anything. You might just need C-Clips.
I'd certainly wait for a recommendation from @GTR1999 before buying stub axles.
Old Jul 4, 2022 | 09:10 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Just so you know... @GTR1999 is probably the singular top authority on these diffs in the whole USA, now that Tom of Toms Diffs has passed. He has rebuilt 100s and is a regular contributor on this forum.
He says GMs heat treating changed around 70-72 or so, and the ones after that wore very quickly. I had a pair that (76) that wore about 1/2" off the diff end. The vast majority of the rebuilt or aftermarket axle yokes available are of very cheap quality as well. Do LOTS of research before buying. Especially do an "advanced search" here for Gary's @GTR1999 comments on the subject of yokes.
Your best option may be to find a pair of original yokes of any year that do not look like they have too much wear, and send them out and have the ends "hardened".
Obviously inspect and measure yours before you do anything.
OTOH if you are not really going to put many miles on the car, it just becomes another "wear item"
Oh and Corvette Mods is not very well regarded on this forum. Van Steel and Bairs are 2 of the best.
Best of luck in your quest!
Old Jul 4, 2022 | 10:32 AM
GTR1999's Avatar
GTR1999
I am addressing axle questions on the C3 Facebook page now, with pictures. If I posted them here some may have an issue.
You have worn axles and probably other potential issues going on inside. 76 was in the range group of problems I listed above. Read and understand it or you will end up paying more for less.
One thing if you think all parts are the same forget it. The quality today varies a lot.
To C3 diff issues?
