1972 AC Compressor install extra wire??
Old Jul 4, 2022 | 06:22 PM
Jhiltonn's Avatar
Jhiltonn
Default 1972 AC Compressor install extra wire??
Hi everyone, I am finally getting my 72 Corvette back together again. Today my buddy and I installed the correct dated GM water pump, the correct r Schwiter fan clutch, and AC compressor. When installing the AC compressor, the stock one mind you, it’s original AC compressor totally rebuilt and original to the car! There’s an extra wire we couldn’t figure out where it goes to. It was near the electrical clip for the AC compressor along with the black ground wire. Does anybody know where this goes? See the two pictures I post thank you Joe from New Hampshire
Old Jul 4, 2022 | 08:37 PM
interpon's Avatar
interpon
Is there an ac idle solenoid on the carb?
also isnt there a thermal fuse on the back?
Old Jul 4, 2022 | 09:24 PM
Jhiltonn's Avatar
Jhiltonn
I believe there is, YES; and there is a long brown wire with a black plastic clip on it connected to the fast idle solenoid already.
Old Jul 5, 2022 | 10:24 AM
kansas123's Avatar
kansas123
suoer heat switch or sumpin like that. goes to back of compressor?
Old Jul 5, 2022 | 12:14 PM
Jhiltonn's Avatar
Jhiltonn
Thanks for your picture from your 72 David! I’m not at home today so I won’t be able to tell if my compressor has this electrical connection or not. Is your Ac compressor original to the car? What’s the build date on your 72? My 72 was built the first week of November 71. I hope that’s the case! Does anyone else have an original AC compressor in their 72 that has this electric connector on the rear of the compressor?
Joe
Old Jul 5, 2022 | 02:04 PM
domenic tallarita's Avatar
domenic tallarita
That wire is for the thermal switch on your back plate. It will dis engage the clutch in case of a overheat in the compressor.
Dom
Old Jul 5, 2022 | 05:29 PM
Jhiltonn's Avatar
Jhiltonn
Thank you Dom!! Good to hear from you! Hope all is well!!
Old Jul 5, 2022 | 07:10 PM
Jhiltonn's Avatar
Jhiltonn
Just so everyone knows: Domenic Tallarita rebuilt my original A6 GM AC Compresssor for me and did a wonderful job!! If you need your vintage Corvette AC compressor rebuilt, contact him directly- he’s the Best of the Best!!!
Old Jul 6, 2022 | 09:46 AM
kansas123's Avatar
kansas123
Yes that is original compressor on my 05/05/72 Corvette.
To 1972 AC Compressor install extra wire??
