1972 A/C Wiring Correct Orientation?
Old Jul 16, 2022 | 07:59 PM
TexVette01's Avatar
TexVette01
Default 1972 A/C Wiring Correct Orientation?
Can anyone tell me which is the correct orientation on these wires for the a/c controller. They will plug in either direction. I don't understand what the wiring schematic is trying to tell me. These are the plugs that connect to the resistors on the left side of the a/c controller.
Old Jul 16, 2022 | 08:33 PM
bmotojoe's Avatar
bmotojoe
Little tough not knowing what line diagram you're going by...
Old Jul 17, 2022 | 11:30 AM
TexVette01's Avatar
TexVette01
I'm using the schematic from the 1972 service manual (pages 1A-64 & 1A-65).
Last edited by TexVette01; Jul 17, 2022 at 11:35 AM. Reason: Uploaded larger images that can be seen
Old Aug 25, 2022 | 09:18 PM
TexVette01's Avatar
TexVette01
Back at it after a long vacation out of the TX heat..Now that its only 90* in the garage I can stand to work on this thing again.
Still trying to figure out the correct orientation of the S1 and S2 wires on the left side of the climate controller. The plugs will slide on the terminals in either direction. Does anyone know what color wire should be "down", as in closest to the floor of the car? The schematic above from the 72 service manual doesn't give a frame of reference.
Old Aug 25, 2022 | 09:40 PM
kansas123's Avatar
kansas123
Next week I will see if I still have a picture of my opened console that might show this connection
Old Aug 26, 2022 | 08:12 AM
bmotojoe's Avatar
bmotojoe
In reality it really doesn't matter.
Both S1 & S2 are single pole Normally Open Contacts.
Until S1 contacts are closed (ON) S2 receives no voltage.
When S2 contacts close (ON) it is only then power is sent to a portion of the Fan Speed Switch and the Ambient Switch.
Look at it like a light switch, the light is either ON or OFF.
Old Aug 26, 2022 | 09:25 AM
B_Ocho's Avatar
B_Ocho
Cruising
This is how mine was orientated when I was switching over to vintage air. This view is with the console lifted from the rear towards the gauges.
Old Aug 31, 2022 | 06:35 PM
TexVette01's Avatar
TexVette01
Excellent thank you!
To 1972 A/C Wiring Correct Orientation?
