Convertible top: what is this tiny clip?
Old Jul 18, 2022 | 01:05 AM
troporobo's Avatar
troporobo
Default Convertible top: what is this tiny clip?
I just replaced the convertible top latch hardware on my 72 to correct a mess. The parts kit from Paragon (see 2104K below) included a tiny clip that doesn’t seem to fit anywhere. Any ideas?
Old Jul 18, 2022 | 02:44 AM
Eliredandblack's Avatar
Eliredandblack
I have a 73 convertible and recently had to disassemble the rear latches, because the 49 year old grease was keeping the spring from engaging the convertible top chrome pins. There was no clip like the one you have anywhere on my latch assembly. The part you have can be found on the door latch (rods that keep them attached to the other assemblies). I know, one of my clips dropped down into the bottom of the door and it took me a while to find it. You can call Paragon Tech Support at specific hours to see if the clip was mistakenly included.
Old Jul 18, 2022 | 11:12 PM
troporobo's Avatar
troporobo
Ah ha, that makes sense, thanks!
Old Jul 19, 2022 | 02:47 AM
Greg's Avatar
Greg
Just another Corvette guy
That is actually the safety clip. It comes with all deck lid release kits. I don't know why it doesn't show in the diagram.
What you need to do is place it over the steel latch, line up the holes, then slide the rod through the hole and push the safety clip into place on the rod.
Old Jul 19, 2022 | 01:00 PM
troporobo's Avatar
troporobo
Thanks a lot for that tip. Y’know, I tried to do exactly that, but the end of the clip with the round hole doesn’t fit over the latch. Guess I’ll have to be more persuasive!
Old Jul 19, 2022 | 02:22 PM
'73and'75's Avatar
'73and'75
troporobo -- AIM shows the "clip" as a Retainer, Item 21 in the snip below:
Zoomed in:
It is used on the treaded end of the rod you purchased, and is attached to the bow lock release handle mechanism.
I will check my car tonight to confirm.
Old Jul 19, 2022 | 02:53 PM
troporobo's Avatar
troporobo
Thanks for that, it's very helpful. However, I don't understand the function of the clip if installed behind the latch mechanism as shown, as it would then provide no additional security to retain the rod if the nuts came loose. I tried to fit the clip over the latch mechanism but it's not wide enough.
Old Jul 19, 2022 | 03:41 PM
Greg's Avatar
Greg
Agreed. '73and'75's photo is much better than the Paragon diagram but it doesn't actually show the clip properly either.
The clip needs to straddle both sides of that hole, then be clipped onto the rod.
Old Jul 19, 2022 | 11:23 PM
Mooser's Avatar
Mooser
FWIW (and I don't have a vert) those clips come in many different sizes as well as L/R versions. When I redid my door mechanisms I bought a "kit" from one of the vette suppliers and about half of them weren't the right size to clip over the various brackets that the rods went into. Ended up buying a "help" package from NAPA that I could use to replace the ones that weren't right
M
Old Jul 20, 2022 | 08:43 AM
'73and'75's Avatar
'73and'75
troporobo -- here is a pic from my '75 convertible. It shows the clip installed on on one side of the bracket (lever) and the 2 nuts on the threaded side. It appears the clip does not straddle both sides of the hole..It appears the AIM drawing is corrrect.
If I had to guess as to the function of the clip, I would guess its purpose is to create some distance between the curve or bend in the rod and the lever, so the rod passes through the hole nearly perpindicular. If the clip wasn't there, the curved portion of the rod would be against the hole, causing it to bind. Just a guess.......
I hope this helps.
Old Jul 20, 2022 | 12:04 PM
Greg's Avatar
Greg
I believe that clip is installed wrong. It's not doing anything. The one in Mooser's pic is correct.
Old Jul 20, 2022 | 12:32 PM
Mooser's Avatar
Mooser
No, I think he's correct, they aren't using the clip as designed, that's why the double nut on the end of the shaft there, I believe he's correct in the assumption that they used it as a spacer.
The 72 AIM is fairly clear on the rather odd install of that clip
M
Old Jul 20, 2022 | 12:35 PM
'73and'75's Avatar
'73and'75
Holy crap Greg -- I must be blind. I did not catch this earlier.
On the AIM sheet I posted earlier is View "C"
Here is View C blown up:
So the clip as installed on my car is installed as per the AIM.
Old Jul 20, 2022 | 09:38 PM
troporobo's Avatar
troporobo
So I tried both ways. The clip simply doesn’t fit over the latch mechanism. View C from the AIM is correct. My guess is that it takes up slack in the threaded rod and is there to improve the geometry of the connection and eliminate a potential rattle.
Old Jul 21, 2022 | 09:06 AM
LT-1 kid's Avatar
LT-1 kid
yes your are correct it eliminates the rattle
Old Jul 21, 2022 | 09:38 AM
Eliredandblack
You gotta love Chevrolet! My 73 convertible lid control doesn’t have the clip. So I checked my 73 AIM, and there is no clip in the illustration or part number referenced. Also the drawing looks to be dated 3-14-72. Maybe the clips were so expensive that the bean counters had them deleted.
Old Jul 21, 2022 | 09:59 AM
Mooser's Avatar
Mooser
And the blue AIM up farther is from a 75 and they put it back, wonder about the 74...
M
Old Jul 21, 2022 | 10:17 AM
Eliredandblack
The really only good thing about being old … I never hear any rattles or noises when driving, of course when my alternator was whining, my buddy at the car show had to let me know.
To Convertible top: what is this tiny clip?
