Which PCV valve?
Old Jan 4, 2003 | 07:18 PM
74FLCONV's Avatar
74FLCONV
Default Which PCV valve?
Picked up a Purolator PCV valve today (Part # PV774) as the book (and their website) called for ('74,350, 4bbl, J vin).
When I installed new valve, it was loose in its holder. The valve that I removed (unknown manf., stamped 7684) has a snug push-fit. When compared side-to-side, old valve was only s-l-i-g-h-t-l-y bigger around its base.
D. Ocean
Miami, FLA
Old Jan 4, 2003 | 07:58 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Default Re: Which PCV valve? (74FLCONV)
The larger old valve streched the rubber grommet. You may have to replace the grommet if the new valve is to loose.
Ed
Old Jan 4, 2003 | 08:43 PM
Paul L's Avatar
Paul L
This is not as simple as it seems. I recommend that you go to a GM dealer and get the proper PCV for your engine.
Old Jan 4, 2003 | 10:31 PM
lyonsh's Avatar
lyonsh
This is pretty common with the Purolater PCVs. Just wrap some electrical tape around the outer circumference to increase the diameter. Works like a charm.
Old Jan 4, 2003 | 10:50 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
i would suggest using a genuine GM PCV valve as i have seen oil consumsion problems cause by after market PCV valve. i had one customer who rebuilt his engine and it still used oil and changing to a genuine GM valve solved the problem. :chevy
Old Jan 5, 2003 | 02:57 PM
Wrecked82's Avatar
Wrecked82
Default Re: Which PCV valve? (clem zahrobsky)
Aren't PCV's just a check valve with what I will call a weight for the valve? What is special about a GM valve? I have the same problem, which I agree seems to be the PCV body diameter fractionally too small, allowing some oil leakage.
Old Jan 5, 2003 | 05:25 PM
clem zahrobsky
Cruise-In I Veteran
Default Re: Which PCV valve? (Larry82)
i do not what the difference is but what got me on to this was a GM bulletin about oil burning in some cars was caused by the PCV not being a GM :chevy
Old Jan 5, 2003 | 05:40 PM
Paul L's Avatar
Paul L
Clem,
I replaced three PCVs in GM Sierra Vortec trucks in the last two weeks for this reason. There is a recall related to excessive oil consumption. It does concern the weight of the internal component of the PCV and what that component senses as normal vrs. excessive blow-by. But if your engine is not stock then this reasoning is not valid.
Old Jan 5, 2003 | 08:17 PM
clem zahrobsky
Cruise-In I Veteran
Default Re: Which PCV valve? (paul79)
my experience was 20/30 years ago but i guess that it still happens today. :chevy
To Which PCV valve?
