Mechanical Fuel Pump
Old Jul 28, 2022 | 08:50 AM
Countryside Cafe's Avatar
Countryside Cafe
Default Mechanical Fuel Pump
C3 1979, I purchased a new mechanical fuel pump that does not have a return line fitting like the original. Can the return hose be plugged off. What should be done about the return hose Thx.
Old Jul 28, 2022 | 09:38 AM
Bikespace's Avatar
Bikespace
You'll be better off with the correct fuel pump. I'm not saying you won't still have issues with vapor lock with a return line, but you'll be even more likely to have vapor lock issues without a return line.
Old Jul 28, 2022 | 10:11 AM
lars's Avatar
lars
You bought the wrong pump. The return line system is very effective in reducing or eliminating the chances of vapor lock issues, especially when running the modern pump gas blends. Rather than hacking your car, buy the right pump.
Lars
Old Jul 28, 2022 | 06:30 PM
kossuth's Avatar
kossuth
Be careful here. As others said you want your vent. If this is a NCRS candidate then consider getting your pump rebuilt. If you are getting anything but a NOS AC Delco (if they can even be had anymore) your wasting your money and possibly inviting problems. Do some searches on here about aftermarket mechanical pumps and you’ll find most if not all are junk out of the box. Only a handful of ways to go about it and be relatively sure you wont have problems.
Old Jul 28, 2022 | 07:27 PM
wilcar's Avatar
wilcar
Lars
Carter M6955
Old Jul 29, 2022 | 03:05 PM
Countryside Cafe
I was able to return the Holly 2 port and I ordered a Carter 3 line exactly like the original. I hope it works well with the 650 CFM carb. - it shoud. Thx
Old Jul 29, 2022 | 04:48 PM
Bikespace's Avatar
Bikespace
Please update the thread once everything is up and running, and please include a part number, and a photo!
Threads like this with a resolution can help dozens of Corvette enthusiasts who never even post on the Forum.
To Mechanical Fuel Pump
