L48 engine temps
Should I be concerned?
John
Bought my high school dream car!
Lars
Yours is clearly not coming up to temp.
Running spot on. Your temp guage should be pointing just a fuzz below the 200 mark. anything below 215 is OK.
Anything above 190 is OK. Below 190 the engine is COLD. it will not run properly until it comes up to temp.
This I know from many years of experience with this car and many others with a gen 1 chev V8.
As Lars stated, get the proper thermostat in there to start with. Then go from there.
If you ever wrote a book on How To keep Your C3 Temps Under 200
You would sell 10,000 copies.
Unless you still have all the emissions crap still on there, such as sensors at the waterneck, the lower temps will do no harm.
It's still hot enough to remove condensation from oil and cast-iron parts.
However, I suspect you are either misinformed about what the dash marks on the temp gauge represent.
Or, the sending unit is suspect. If the wire to the senders terminal is loaded with grease, there is the poor GRD or poor reading.
If you have ever been to a drag strip, the staging lanes are NOT used to bring coolant temps up to 200 for better performance, hint-hint.
If all checks good, the first thing to check is your timing. Most out-of-tune Corvettes are severely retarded, and this is the biggest contributor to high engine operating temp. Make sure your timing is set up for 36 degrees total with resultant initial timing in the mid-teen range. Make sure your vacuum advance is functional and hooked up to manifold vacuum, which should make your actual timing at idle about 30 degrees.
If this does not solve the issue, you need to start looking at radiator condition, capacity, and airflow through the radiator, which includes assuring that the car has the correct, stock fan with a functional fan clutch. Many cars have been "modified" with POS "flex fans" and other horrible aftermarket components. The integrity of the seals around the radiator, and the position of the fan in the fan shroud are also very important aspects to Corvette engine cooling. Inspect everything - most of these cars have been modified and messed with over the years, and simply bringing them back to the stock, correct configuration does a remarkable job of making them run right.
Lars
Lars
Harbor Freight sells those temps guns they are super cheap.
These cars suck up every bit of debris from underneath. Do you have the airdam underneath?
On any vette, once a yr i remove the fan/shroud and from the backside blow out the fins with a garden hose (not apressure washer or youll flatten the fins)
Youll be amazed at how much crud comes out..take your time. Works great on other coolers, condenser for ac etc I do the condenser at home the same way it really helps.
Lots flush, change coolant but I never see guys do this. Buddy loaned me his Expedition last week...that radiator has to be over 3 ft wide
90k mi and plugged solid. Ac now get super cold right now fans run way less
First make sure your timing is correct that can have an effect on temps..then adjust carb if need be, ck your cap etc.
In warm climates I like to use the Milodon 160 hi flow stat. A std stat Ill drill 3 1/8" holes around the outer ring to prevent air pockets
The ECH RR171 IMO is the better of the 2 Napa brand caps they sell.
The ECH RR171 has the Brass terminals.
The MPE RR171SB has what looks like tin plated terminals.
Either of the 2 caps should fit correctly.
You will see (2) Items #1s and (2) items #2s
There is a difference in the thickness of these seals.
Make sure all the radiator support seals are there.
The also don't require channellocks to remove, like the original one did (pictured, left). The box on the right is the current ACDelco replacement. This was for a 79 L48, so the part numbers may be different for your car.
Please post some pics of your setup! For a start, is your vacuum advance connected?
Water boiling point is 212F, at 15 psi that boiling point is increased to 249.8F. A 50/50 mix of water and antifreeze will add 11F buffer to those number so in reality the car pukes out the overflow when the water temp is 260F or higher.
If your car is truly running at 240 - 260F I would expect to see some level of boil over at shutdown, all that aside 240 - 260F on gauge is too hot for an L48 to run so you have issues to sort out.
Owning a Corvette is a special thing! Having your High School Dream car is even better!
My Uncle had a 1969 with side-pipes and I knew back then I would have to have one someday. I have been lucky as I have had my 1968 BB Convertible Corvette since 1991 and my 1988 since 1994. Corvettes are special and require more tender loving care than many older cars. Here on this Forum you should find plenty of experts to help you out with your "New to You" Corvette! Take your time and be sure to buy the GM Factory Service Manual (FSM) as well as the Assembly Information Manual (AIM) for your year Corvette. The factory manuals are better and more accurate than any aftermarket books. They have better troubleshooting guides and schematics in them.
On my Corvettes I run 70/30 mixtures where I have 70% Distilled Water and 30% anti-freeze because we don't get that cold very often and cooling is more important and that works better when you use more water. Having a infrared thermometer is a very handy tool as you can check your wheels when driving to be sure that they are all close in temperature, with a bad wheel bearing or stuck brake caliper it would show up quickly. I also check the exhaust manifolds in roughly the same place over each cylinder to ensure that all 8 plugs are firing and everything is working right. There are plenty of uses for the thermometer.
Having a good working radiator cap with an overflow bottle is also very important because as the coolant gets heated up it expands and needs to be collected, stored and drawn back into the radiator as it cools off. So often a broken hose or defective radiator cap can allow air to get into the radiator and that impedes the cooling to have a big air bubble inside the radiator.
Good luck with your Corvette and be sure to get it up to date and as "safe" as possible. Replace the belts and hoses and check the brakes to be sure that you are in a safe car. Brake fluid should be flushed every couple years at most as older brake fluid can cause lots of trouble rusting through the lines and damaging the brake calipers. There are lots of places that need attention on an older Corvette but the guys here are here to help you in any way they can. There is a lot of experience here on the Forum. Just be sure to put as much as you can on the profile so people can look up your Corvette and see what you are talking about. Any Modifications are very important as we need to know about them to help you more effectively. Be sure to check the tires and don't drive fast on tires over 10 years old. Corvettes are a lot of fun and are fairly easy to work on and take care of.
Best regards,
Chris
