I'm in the process of putting an alarm in my 75 and could use some advice. I've identified all the wires I need to tie into the Corvette wiring harness,I'm in a little stumped with the wiring harness for the alarm. The alarm in question is a Viper 5706 V. Even though the alarm has options I'm only using the basics. Shouldn't there be an input/output wire in the alarm harness for the starter interrupt feature? On top of all of this I can't find the wiring diagram for the alarm,found it online.
I wish I could help but I don't know enough about these cars' electrical systems. I guess if it was me and I had found the schematic, I would try to install it ignoring the the use of any of the OEM system. I hope someone comes along soon to help you.
I just installed that alarm on my 1980 corvette last month. Did you figure it out?
green wire and the violet wire thick wires on the side of module.
