Steering shaking
Old Aug 29, 2022 | 10:40 AM
Corvettesteadele's Avatar
Corvettesteadele
3rd Gear
Default Steering shaking
Hey guys, is it normal for a Corvette 1976 steering to shake on rough pavement ? When pavement is even the car is running smoothly, when pavement is bumpy it transfers to my steering wheel... should I be worried?
Old Aug 29, 2022 | 11:07 AM
MelWff's Avatar
MelWff
Is the car a recent purchase?
it's not going to feel like a modern car on any kind of road.
What cold tire pressure are you using?
Have you or anybody checked ball joints, tire rods, idler arm, steering box, steering coupling, control arm bushings, shocks, etc. ?
Old Aug 29, 2022 | 11:13 AM
Corvettesteadele
3rd Gear
Thanks Mel for your quick answer.
Is the car a recent purchase? No, I had this car since 2000... I had it restored with original parts and kept it in storage for a couple years...
What cold tire pressure are you using? 35 psi Radial TA
Have you or anybody checked ball joints, tire rods, idler arm, steering box, steering coupling, control arm bushings, shocks, etc. ? The last time I went to a garage with it they told me all was good.... but the car was taken to a GM dealer and for some reason I feel like I should have it inspected by a more experienced mechanic.
I just don't remember the steering transferring every bumps of the pavement to my steering wheel...
Old Aug 29, 2022 | 11:23 AM
MelWff's Avatar
MelWff
It's somewhat of a controversial topic but in my opinion if you want a smoother ride over rough roads, drop your tire pressure to 30 PSI cold, 32 at most. Others site load rating on sidewall pointing to high numbers but you are no where near maximum load when mounted on your car.
Old Aug 29, 2022 | 11:27 AM
Corvettesteadele
3rd Gear
Great, I ll try that !!!
Thank you for your advice
Old Aug 30, 2022 | 09:51 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
How old are the tires? If you never changed them, when they dry rot ghey can get stiff.
If you have manual steering and a steering damper, the damper could be dead
To Steering shaking
