Transmission Issue Stalling in 1st
Old Sep 4, 2022 | 03:04 PM
kyn99001's Avatar
kyn99001
5th Gear
Default Transmission Issue Stalling in 1st
My first post was about how to get more horsepower and my second is on a transmission issue. I guess that is how it goes!
I had a weird issue that I am not sure of. I wanted to do a WOT run from a stand still. I put the shifter in first held the brake a bit and floored it while holding the brake for a breif moment. When the car took off it got to about 2000 rpms and stalled out like something was binding in the transmission.
I put it back in drive and it continued to work properly. There was a bad smell briefly like something burned a bit. The thing I can't figure out is that the transmission didn't seem like it was slipping it just held about 2000 rpms and wouldn't go any faster till I put it in drive. From there the car seemed to shift and run fine. I have done a couple WOT runs with it just in drive and it does fine.
I did check the transmission fluid today and it smells burnt and is a little darker. What would cause this?
Old Sep 4, 2022 | 05:33 PM
kodpkd's Avatar
kodpkd
It has an original 50 year old transmission?
Old Sep 4, 2022 | 09:14 PM
Motorvation's Avatar
Motorvation
Cable/ shifter adjustment may be off. But going into two gears at once locks the trans up, i.e. the back wheels should slide. No selection in the converter.
Steve O.
To Transmission Issue Stalling in 1st
