Engine removal / gearbox
Old Sep 7, 2022 | 11:22 PM
Mojoman69's Avatar
Mojoman69
Cruising
Default Engine removal / gearbox
I have removed the gearbox and clutch assembly to put new clutch in my '69 C3. Noticed a couple of the old gaskets leaking so I have decided to remove the engine. There is not much more to do to pull engine and freshen it up. But the question is when I go to put it back in should I attach the clutch/bellhousing/gearbox to the engine and install it all together or just bolt on the clutch and bellhousing and drop it back in and then attach gearbox
Has anyone done it both ways and what way would be better?
Old Sep 8, 2022 | 12:34 AM
lars's Avatar
lars
Install the complete engine & transmission as an assembly. It's the only way to do it.
Lars
Old Sep 8, 2022 | 12:58 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The easiest way is as one unit. Can you do it with the motor installed, yes but it is a hassle, especially if you have the stock welded in transmission crossmember. It can go in, tailfirst on its side with the muncie shifter bracket removed but it is a complate hassle, especially if the input shaft and the clutch assembly werent mated begore hand.
Dont do it one then the other, it will take onger and be a big headache.
If you pull the radiator and hood you can get it to slide in especially with an engine leveler/tilter
Old Sep 8, 2022 | 02:59 PM
Mojoman69's Avatar
Mojoman69
Cruising
Thanks for the advise. I was thinking about doing it all together but was not sure how much of an angle it would take to slide it in. But it does not look that bad. Thanks for the pic's.
To Engine removal / gearbox
