Spreader bar clearance
Old Sep 11, 2022 | 05:14 PM
Shovels and Vettes's Avatar
Shovels and Vettes
I put the same spreader bar on my 77, and it was absolutely a noticeable difference. My challenge now is to find a way to put it on my 69, with the big block. I want to use factory clutch fan, as I am not interested in electric fans for the car. And apparently.....there is not alot of room. It is my plan to find a way. Time will tell.
Old Sep 11, 2022 | 05:23 PM
sunflower 1972's Avatar
sunflower 1972
I found this: https://www.corvetteforum.com/forums...lock-guys.html
Old Sep 11, 2022 | 07:45 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Question to OP. Is that 1" dia x 22" bar and 5/8" ends by chance?
Old Sep 11, 2022 | 09:34 PM
docohm's Avatar
docohm
My spreader bad is just as close and works just fine. Never touches the fan.
Old Sep 11, 2022 | 10:18 PM
augiedoggy's Avatar
augiedoggy
Mine clears even with this different waterpump and pulley.
Old Sep 13, 2022 | 01:33 PM
twinpack's Avatar
twinpack
That's about where mine is. Its been fine foe 2 seasons now. Don't even think about is anymore.
Old Sep 13, 2022 | 05:37 PM
Shovels and Vettes
Default Solution
Originally Posted by sunflower 1972
I read that thread when searching for solutions. I think it is a good solution, I just concern myself with moving the fan forward, considering if it would in any way buy additional load or stress on the water pump bearings, and if moving the fan further into the shroud has any unexpected consequences. I may be over thinking it, as its not much of a spacer. ????
I know having electric fans makes this easy.....but I a simply not interested in electric fans, no matter how much better they may be.
Old Sep 13, 2022 | 09:10 PM
MelWff's Avatar
MelWff
Just researched the spacer I used. It's from March Racing, Summit's part number is MCH-350, 5/8" thick.
