L71 solid lifter adjusting nuts loosening by themselves
Old Nov 23, 2022 | 09:40 AM
derekderek's Avatar
derekderek
the other 14 have been adjusted as many times as the 2 loose ones. you have ll winter...
Old Nov 23, 2022 | 10:37 AM
Hopper12's Avatar
Hopper12
I'm sure you're right Derek. I wanted to do the two that were a problem first to see how the new nuts worked before deciding to do the rest. I'll replace them all during the winter while I'm doing other stuff. I believe this will solve the issue but, if any of them loosen up again, it'll be new studs and poly's. Never a dull moment on these C3s!
