Tips for installing trans dip stick
I am reinstalling the th350 trans back in the car, The transmission is already mounted to the engine only has 2 bolts and still on the trans jack. But this darn dip stick doesnt want to go in any way that I try to put it. How have you guys done it in the past?
Make sure you have the correct O-ring on it. Lube up the O-ring with a few drops of tranny fluid, and then put the tube into the hole until the O-ring starts engaging into the hole. Then, do a combined wiggle-with-rotation back and forth while applying light downward force on the tube. It should slide in smoothly. If not, remove the O-ring and verify that it goes in without the O-ring. If it does, you may have the wrong O-ring installed, or you have a burr or defect in the hole in the tranny case.
Lars
Lars
While I had it mounted to the engine, I only had two bolts in while it was on the trans jack still and was easy to remove and drop it a bit to get some more clearance. Thankfully I was able push it from beneath the car. the problem was getting the end of the dip stick over the what I believe was the servo housing. After that I was able to put the dip stick in the hole it goes to but now I cant get it twist to have the tube's mounting hole in place on the transmission/engine mount to bolt it. More fiddling will be needed. So defeated over a seemingly simple task haha.
Thank you for the pictures too, I wasn't sure if it actually bolted there only guessed and it's what I've been trying to do lol. Had to take a break a couple hours ago because my arm started thriving in pain for some reason. It's all good now though, about to go back out there.
The tube goes in nice and easy one way, but isn't lined up to bolt down.
When i try to put in to where I can bolt, the end of the tube is at such an angle that it makes it not possible to go in anymore than pictured. I then lined up the tube mounting point to see how far off it would be. I have no idea how this was ever installed in the first place.
Correctly installed on the bottom
When correctly put into the trans at the bottom this is how it lines up at the top
How it looks when trying to line up mounting point and insertion point. It's at such an angle that it will no longer go through
BTW, I did the exact same thing as you with my BB and TH400. What a pain in the *** that was to get it in place - as I recall it was a combination of lifting the engine off the mounting horns with the rear cross member removed so the trans could drop down, plus a lot of swearing and twisting and cursing and finagling and scraped knuckles and pushing and pulling of the tube. Finally went in but now I don't know if the O-ring was in place!
Full disclosure. I drink home brews while I work on the Vette so either I get super human strength, or can’t remember how I got it done.
I don't know that you can get the tube in with the engine/trans installed in the car. Unfortunately, you did things in the wrong sequence: A little bit like mating the tranny to the engine without the torque converter installed and saying you're going to install it later. It doesn't work. You will probably need to pull the engine mount bolts out, pull the tranny mount bolts out, lift the engine, move it forward, and then install the tube. Then, slide the engine/trans back and down and install it.
Lars
But, turns out 79 and later c3’s switched to a hat-shaped seal instead of the O-ring. Got this one from Summit to make sure it never leaks again.
Definitely takes exactly the right tweak to get the tube aligned, but if was in there before, it’ll fit. Fit the tube in the tranny first, then worry about twisting the mount into place. Might be easier to get that hat seal out and put it on the end of the tube.
Charlie
Kerschmolar My th350 did in fact have the hat top gasket and not an o-ring. Which is good to know because that means it's probably the original transmission for the car but was rebuilt with a shift kit before I bought the car back in 2012.
I ultimately decided to get the Lokar flex tube, I leave the country soon and I don't have the time to play around with stuff that wants to fight me. If anyone decides to go Lokar like I did, you have to take the hat top gasket off the Lokar first and put the gasket in the transmission before you install the tube or it wont go in all the way. Don't know about other year corvettes but with the 81' like mine, there was a bolt sticking out of the top of the heater core box that had a lose nut on it, basically begging me to mount it there instead of drilling new holes into the firewall to secure it. Do keep in mind that there are different versions of the Lokar, the one I got was specifically for the th350. I also made sure that the dipstick itself was the same size as the original stick too, so I know it's going to read correctly.
Mine is tye-wrapped to the bracket for the wiper-door actuator ....I did not want to drill holes until I made sure it worked well there...
