76' L82 Intake Manifold/Timing
Old Sep 16, 2022 | 09:31 AM
x IRON EAGLE's Avatar
x IRON EAGLE
Default 76' L82 Intake Manifold/Timing
I need to replace my intake manifold gasket. What are the recommended torque specs for the manifold. Also, I'd like to make my timing more aggressive. The car is only modified with a true dual exhaust, no cat and all of the smog equipment removed. What is the most aggressive setting I can go without damaging the motor?
Old Sep 16, 2022 | 09:48 AM
HeadsU.P.'s Avatar
HeadsU.P.
Cast Iron 30
Aluminum 25
Torque in 3-4 steps / sequences.
Snug
10
20
30
Then another 30 after heat cycles.
You are not likely to be able to use a torque wrench on eight of the bolts anyway. Just use a box-end wrench and get a "feel" for what is needed.
Obtain a copy of SBC Intake Manifold Torque Sequence off of the internet. Print out a copy and lay it right the carb pad for reference.
Old Sep 17, 2022 | 09:04 AM
ScottinMaine's Avatar
ScottinMaine
Read Lars Grimsrud's paper on ignition timing, it's pretty complete and almost universally agreed advice.
To 76' L82 Intake Manifold/Timing
