I’ve been on the fence about rebuilding my own TAs or taking them to Van Steel. I live less than two hours from Van Steel and work in that area on occasion so I do have that as an advantage. When I review what needs to be done to rebuild them it doesn’t seem like it’s too bad a job for a diyer. What are you alls thoughts on this for those that have done it?
it's doable , you'll need the wheel bearing tool and you'll need the tool that flairs out the steel inner sleeve when you install new front bushings in the TA , I have the wheel bearing tool but improvised on the flairing tool , if I did it again I would buy the flairing tool , on mine I replaced everything from hardware , backing plates , wheel bearings, e brake shoes , cables and hardware on my black 80 and install one item in the wrong order and you have to dis assemble the whole thing , if I had to do the same for my white 80 I'll probably buy the exchange from Van Steel just to save the time
Van Steel is local for me as well. They did the trailing arms on my 66 and 68. I even installed poly in my 66 that promptly broke apart. They replaced the bushings while I waited. The labor was free. I paid a nominal fee for the bushings. Why take a chance. By the time you purchase the tools, sand blast and powder coat the arms, it is more cost effective to have them done by Van Steel. Jerry
I just got mine done by Gary Ramedei (GTR1999) here on this forum for my 64. Can't say enough about how well they came out. Attention to detail and excellent service. I would certainly have him do another set.
I bought some of the tools, made some of the tools back in the early 90's. Just to properly grease the bearings you need to press out spindles. So owning tools makes sense.
Geez, I only changed the front bushings the one time, but have had spindles out numerous times over the years.
And a fair few friends like to borrow these tools as well.
If your keeping the car long term. Buy the tools. Learn to setup bearing end play, (It's just like doing 73-99 Harley wheels and I'm a Harley mechanic).
The next time you need to work on something back there or just want to grease things. You'll be glad you have the tools.
I’ve had it 15 years and it’s definitely staying with me for the long term. Thanks for the advice.
Cost doing it yourself, one shim kit for spindle bearings, buy a full kit with a center spacer, Sometimes switching center spacers can get you closer to min spec without the need to surface grind shims. Timken bearings are available at every bearing shop. Very common bearings. Outer seals. Cheap as.
Rubber bushings for front of arm. Also cheap.
Cost to rebuld them yourself is VERY low. If your spindles are shot. Well, that costs.
Nothing difficult about doing this if you have the correct tools, the cost of new bearings, bushing, seals etc. won't break the bank. In addition to special tools you will need an air compressor, sand blast cabinet, shop press etc. to go along with those "special tools" you will have to buy. I have all of the above and have rebuilt two sets of T/A's so it's doable for the DIY'er.
What you have going for you that most people do not is that you are local to a location (Van Steel) that does this for a living so you don't have to pay for outrageous shipping cost. If I was in your shoes I would just drop them off at VS and call it a day.
it is worth it for 4-vettes as he is in australia. trailing arms are among the few jobs on our cars that farming out makes more sense. rears, auto trans are a couple more. exhaust and windshield are on the fence.
I don't know Derek, I purchased tools and made a few long before I moved to Australia.
Setting up timkin bearing end play or staking a bushing sleave is just not Rocket science.
And No, I don't care what side of the planet I'm on. Can't see paying someone else to do a job I can do myself.
Now painting??? Well, that's outside my patience level.
If you have all the tools it is not bad. Most folks though do not have dial indicators, setup tools, press, and other items needed to do the job though.
Agreed with the paint comment. I do have the bearings I bought a while back. Timken. I’m on the fence right now. But I have time since funds are low at the moment.
I have a compressor, and dial indicator. Don’t have a press and would have to farm out the blasting.
Air compressor or a spring compressor? Take a look at this thread and you can see what you would be getting into and some of the tools involved. Gary does really good work and can be found on this forum as well. https://www.digitalcorvettes.com/thr...uilding.77000/
