Convertible Top Cleaner
Old Sep 23, 2022 | 06:39 PM
ntmyzr1's Avatar
ntmyzr1
C7 of Year Finalist (track prepared) 2019
Default Convertible Top Cleaner
My '68 Corvette has its original white convertible top. It's still in very good condition. I clean it using Simple Green and a brush. There are a few stains that I can't budge with the Simple Green. I'd appreciate a recommendation for a stronger product that will not hurt to top.
Thanks.
Old Sep 23, 2022 | 08:23 PM
Motorvation's Avatar
Motorvation
Find some 303 products. https://www.goldeagle.com/product/30...e-top-cleaner/
And then the Protectant https://www.goldeagle.com/product/30...SAEEgI0FPD_BwE
Good stuff. May find it at Auto Zone.
Steve O.
Old Sep 24, 2022 | 09:49 AM
Capt. Doug's Avatar
Capt. Doug
Default Top cleaner
I used Comet on my 57 convertible and my 62 vette. It took out the stains and kept them white white.
Old Sep 24, 2022 | 10:08 AM
interpon's Avatar
interpon
NON flammable brake cleaner…
try a small area
Mooser's Avatar
Mooser
The one I use for my AM tops (same material) is RaggTopp, the pair of a cleaner and protectant like the 303 mentioned above. Been around for a long time, good stuff
M
Old Sep 24, 2022 | 10:09 AM
ntmyzr1's Avatar
ntmyzr1
Thank you Capt Doug. Now that you mentioned it, I believe that was my Dads go to produce. I'll give it a try.
Old Sep 24, 2022 | 10:12 AM
ntmyzr1's Avatar
ntmyzr1
I've used brake cleaner to get the stains off the aluminum intake manifold, but would be hesitant on the top. Unfortunately there is no good area to try it out on.
Old Sep 24, 2022 | 10:15 AM
Street Rat's Avatar
Street Rat
As Mooser said above.
Raggtop
Old Sep 24, 2022 | 11:31 AM
interpon's Avatar
interpon
non flammable chlorinated brake cleaner is essentially dry cleaning fluid
Old Sep 24, 2022 | 04:29 PM
REDONBLACK69's Avatar
REDONBLACK69
Has anyone tried BleechWhite whitewall tire cleaner?
Whatever you choose to use. PROTECT THE PAINTED BODY!!!!!
Old Sep 24, 2022 | 05:19 PM
Z51JEFF's Avatar
Z51JEFF
I used Simple Green and a tooth brush on stains and the RAGG TOPP products.
Old Sep 25, 2022 | 08:32 AM
toylman's Avatar
toylman
A lot of products work, but use Mr Clean's Magic Eraser. It is almost magic what it can do.
Old Sep 25, 2022 | 01:55 PM
Crider's Avatar
Crider
Sort of on the same topic, what is a good product to protect and shine the top that won't run down and streak the car when it gets wet?
Old Sep 25, 2022 | 06:33 PM
ntmyzr1's Avatar
ntmyzr1
Thank you for all your recommendations. Lots to try to see if something can budge some old stains.
Old Sep 26, 2022 | 06:23 AM
toylman's Avatar
toylman
This is the Original white top on a 1972 I owned in the past. After trying everything that did no damage, I used a Magic Eraser with a mild soap solution.
To Convertible Top Cleaner
