C3 Radio question
Old Sep 24, 2022 | 09:59 AM
Mikey857's Avatar
Mikey857
Default C3 Radio question
My am/fm radio convector is bad. Is there a place to get a new one or to get existing one fixed?
If not, can anyone make a good suggestion on radio replacement that looks like the old one and sounds good? I have looked at numerous sighs and most of the ones I’ve seen with two **** don’t look good or seem cheaply made. I have a pretty much unmolested 73 so I don’t want to cut anything up. I searched the forums with no luck. I’m hoping some one else has already gone through this and found something good.
thank you!
Old Sep 24, 2022 | 10:18 AM
Mooser's Avatar
Mooser
If you're ok with the existing radio, the convector is a simple transistor in a large heatsink, if you can't find a replacement used one (still 50 years old) you should be able to get a NEW transistor (NTE105 is a listed replacement) for about $20-25 and it's pretty simple to replace
Now if you want to upgrade to a different radio with blue tooth or sxm then that's a different thing all together
M
Old Sep 24, 2022 | 10:21 AM
A10pilot's Avatar
A10pilot
I was looking for a new radio for my '69. Stopped looking for now because...life.
Try these guys. I called them once and they said they had a Slide Bar II coming soon.
This seems like a high price (I was thinking more like <$400) but they seem to have the best modern OE looking ones.
https://www.classiccarstereos.com/19...6adbae574dfbb0
Hope this helps
Old Sep 24, 2022 | 10:55 AM
Motorvation's Avatar
Motorvation
I bought a RetroSound that looks fairly correct, even has black *****. Is Bluetooth accessible, 1/8” plug in, and Sirius XM compatible. Although da hell if I can figure out how to access the options. I’m happy with the FM reception and the sound is ok with the top down. I unhook my battery when I leave the car in storage, so I need to redo station memory every time I cruise.
https://www.retromanufacturing.com/p...41993267544220
Steve O.
Old Sep 24, 2022 | 10:57 AM
kodpkd's Avatar
kodpkd
What are the signs that the radio convector is bad?
Old Sep 24, 2022 | 11:04 AM
Mooser's Avatar
Mooser
Typically it just stops working (no sound or a buzz) or stops working after a few minutes when it heats up
M
Old Sep 24, 2022 | 12:15 PM
stevedinino's Avatar
stevedinino
Originally Posted by Motorvation;[url=tel:1605713729
1605713729[/url]
I have grown to hate my Retrosound. Every button and **** seems to have at least two or more functions depending on what mode you’re in. Counterintuitive is putting it mildly.
I have a 1982-ish Delco am-fm stereo on my bench right now, in the process of adding Bluetooth to it. It’ll be simple and straightforward, and will look correct.
Old Sep 24, 2022 | 12:22 PM
kodpkd's Avatar
kodpkd
Mikey,,,,,, Does your radio make any sound? Are you sure your speakers work?
Old Sep 24, 2022 | 01:33 PM
Mikey857's Avatar
Mikey857
Power to radio, power coming out of radio to convector. Not even static from speakers.
Old Sep 24, 2022 | 01:34 PM
Mikey857's Avatar
Mikey857
No sound at all
Old Sep 24, 2022 | 02:02 PM
Crimson Thunder's Avatar
Crimson Thunder
Put a WTB (want to buy )thread for one on the parts page.
Old Sep 24, 2022 | 02:03 PM
Mikey857's Avatar
Mikey857
Just a different thought, would a later year work?
Old Sep 24, 2022 | 09:57 PM
kodpkd's Avatar
kodpkd
Are you sure the speakers are hooked up and working?
Old Sep 25, 2022 | 08:17 AM
Mikey857's Avatar
Mikey857
Yes they are
Old Sep 25, 2022 | 09:03 AM
Avispa's Avatar
Avispa
This might be pricier than you want, but if you don't want to cut up the dash or put in a not quite stock looking aftermarket radio, this might be an option.
http://garytayman.com/
I did this conversion on my 66 in July. Bought a non working C2 radio on eBay that had all working mechanical parts, and sent that for conversion. My original radio is in storage. Also put in a dual voice coil speaker. Very, very pleased with the result. You can add Bluetooth and/or USB for a bit more. These come with 4 speaker outputs if you want all that in your car.
Funny thing, I moved my car to Maine 5 years ago, but never really used the radio, which was working before. Thought AM had gone bad. Bench tested the new radio in the driveway and didn't get much AM. Bad radio? Nahhh, quick check on line showed the nearest AM station is almost 50 miles away!
Old Sep 25, 2022 | 12:04 PM
GUSTO14's Avatar
GUSTO14
Mikey, be sure to mention whether you have a mono or stereo radio in your search. The mono convector has one transistor, the stereo has two.
My '73 still has its original mono radio, but I found a working stereo radio at Carlisle about 10 years ago... just haven't gotten around to installing it yet...
Good luck... GUSTO
Old Sep 25, 2022 | 12:12 PM
Mikey857's Avatar
Mikey857
Yes, it is a mono stereo with one convector.
To C3 Radio question
Old Sep 25, 2022 | 12:13 PM
GUSTO14's Avatar
GUSTO14
BTW, the radio from '68 thru '76 will all fit in the stock dash.
In 1977 Chevrolet changed the dash to accommodate the generic GM radio to satisfy the increasing demand for 8-track and cassette radios, without having to make a 'limited production' re: expensive radio, so the '77 - '82 radio doesn't fit the earlier dash.
Good luck... GUSTO
Old Sep 25, 2022 | 12:24 PM
Mikey857's Avatar
Mikey857
Do the later years after 73 need the convector too?
Old Oct 5, 2022 | 07:55 PM
Mikey857's Avatar
Mikey857
I did get a new transistor and installed. I still have no sound at all. Not even static. As hard as it is putting the radio back in, I think I’ll just listen to the motor rumble instead of music. I’d like to meet the engineer that designed that system of gauges and radio support…..😡
